Aftermarket Rotors?
Old Jan 5, 2005 | 10:43 AM
2kmaxgle's Avatar
Aftermarket Rotors?
Will aftermarket rotors correct the braking vibration on a 2k max?
If so, what would you guys recommend?
Old Jan 5, 2005 | 10:45 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
vibration might be warpage. new disk like a drilled set that are also thicker will fix that, giving you better stopping power and control.
I had brembo drilled and slotted on my 02..........
Old Jan 5, 2005 | 10:58 AM
2kmaxgle's Avatar
any particular brands?
Old Jan 5, 2005 | 11:00 AM
Cutler's Avatar
Brembo Blanks and Axxis pads are what I recommend
Old Jan 5, 2005 | 11:02 AM
Tek-Niq's Avatar
sorry I can only tell you what I experienced on my 02 and thats BREMBO: front,
rear,
Old Jan 5, 2005 | 11:04 AM
Tek-Niq's Avatar
I used stock pads on my set up FYI and worked great. my .02......
Old Jan 5, 2005 | 11:14 AM
2kmaxgle's Avatar
thanks for the info!
Old Jan 5, 2005 | 12:12 PM
UGAd13's Avatar
Powerslots up front w/ stock pads. Check the Group Deal section for more options.
Old Jan 5, 2005 | 01:38 PM
mhadford's Avatar
You can get Brembo blanks pretty cheap and they WILL solve the stock disk heat warping issue. The stock rotors are absolute garbage.
Old Jan 5, 2005 | 04:04 PM
ColdSHO's Avatar
frozen rotors, ii totally dig mine, but mine r 04s witht the bhlemco brackets. thats the way to go, if u ask me
Old Jan 5, 2005 | 04:30 PM
rbneron's Avatar
The stock rotors are troule...mine warped bad as well. I went with Stillen drilled and slotted; no problems to date.
rbneron's Avatar
Er, trouble.
Apr 16, 2020 05:15 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Socalstillen
Sep 26, 2015 12:01 PM
