Cylinder Layout
Old Jan 6, 2005 | 02:55 AM
2kBlkMax's Avatar
Cylinder Layout
Hey all-
Have a 2000 Max SE and recently had the check engine light come on. My friend's scanner shows a p1320 code along with a code for a misfire being detected in cylinder 5. The 1320 code (from my research) shows that it is a fault in the primary wire in the coil. I'm aware of the coil problems in these cars and was quoted 79.99 at the dealer for a new coil. My question is which one is cylinder five?
Oh yea also a word of advice, if you have a coil going bad thats causing a misfire, I suggest you fix it as soon as possible as its dumping raw fuel into the cat, causing it to overheat.... I also had a stored code for p420 (I think) which indicated a fault in the "stage 3 catylist" which I can only associate with the misfire problem...right?
Also, If my cat is damaged, what's the warranty for the cat alone? Isnt it federally mandated to have a 100k warranty on these things?
Thanks for your help,
Brad
2000 SE Max
Stillen K+N intake
94k on the odo
Nitto NT450 rollers
Stillen CD rotors w/ carbontech pads <----by the way these pads are awesome (rotors suck, though...any suggestions when I replace them?)
....LOVE my Max.....
-Brad
Old Jan 15, 2005 | 10:39 AM
kiski's Avatar
Brad,
From left to right at the front: #2 - #4 - #6
From left to right at the rear: #1 - #3 - #5
The P1320 code is a bad ignition coil.
Steve
Old Jan 15, 2005 | 10:44 AM
MaximaDudes's Avatar
its in the owners manual
Old Jan 15, 2005 | 02:47 PM
schmatt's Avatar
owner's manual says front of the engine, not the car. The front of the engine is on the passenger side, fyi. That info is not in the manual.
Old Jan 15, 2005 | 10:54 PM
2kBlkMax's Avatar
Cylinder layout
Ok...so I'm assuming thats from the view as if I'm staring at the motor from the front of the car....right? Retard here....
Old Jan 16, 2005 | 04:55 AM
kiski's Avatar
That is correct.
Old Jan 16, 2005 | 08:17 AM
00Max00's Avatar
It's unbelievable why so many people dont even have an owner's manual or don't even bother to read it?
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
