Changing Fog Light Bulbs
Old Jan 6, 2005 | 05:14 PM
2002 Maxima SE's Avatar
I followed the procedure on housecor's site. Anyone else have trouble getting the H3 connector unhooked from the black plastic housing. I wiggled it back and forth...then tried two sets of pliers. One pulling on the H3 connector the other on the black plastic houseing...it would not come out.
Finally had to take the black plastic housing apart and bend the female end holding the H3 in place.
Old Jan 6, 2005 | 05:25 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
that weird cause it pops out easy once you take the spring holding it in out......
Old Jan 6, 2005 | 05:28 PM
crispykid717's Avatar
Bigger than Jesus
I changed my fogs yesterday and had trouble pulling out the white cord from the connector. I just pulled real hard and it popped out. I don't know if you can out them in upside down or if it makes a difference which way the go in?? Maybe that's why yours was so hard to pull out??
Old Jan 6, 2005 | 05:38 PM
tek,
Not the bulb, but the connector.
crispy,
I pulled so hard the brass/copper fitting inside the black plastic housing came out the other end. It was still attached to the foglight connector.
Old Jan 6, 2005 | 06:19 PM
Audtatious's Avatar
Bandwagon Lover
Use two pairs of pliers. One to hold the connector, the other to pull the white cord out.
Old Jan 6, 2005 | 08:12 PM
MaximaPolak's Avatar
someone has a brain...it's common sence....since you see the connector moves with the plug, you have to hold the connector in place while moving the plug
Old Jan 6, 2005 | 08:19 PM
That person with a brain wouldn't be either one of you, I posted that in the first post:
Old Jan 6, 2005 | 09:10 PM
LA02MAX's Avatar
yeah, my bulbs were pretty stuck in there, and i also couldnt get the connector off, so i just kinda gave up, and worked right on the bumper w/ the fog actually still connected to the car. I had to use 2 pairs of pliers as well to get the actual bulb, because every time i pulled, only the brass piece would come futher out...once thats done though, its cake. My first one took me probably about 15 min. and the other one took about 5 minutes total.
Old Jan 7, 2005 | 12:50 AM
stevay's Avatar
wiggle it....just a little bit...lalala
Old Jan 7, 2005 | 06:51 AM
Worked for me without pliers and i just used my hands. You have to hold one of the parts down with something and pull the other one.
Old Jan 7, 2005 | 09:17 AM
Audtatious's Avatar
Bandwagon Lover
That's because us people, without a brain, were able to disconnect the wires using two pairs of pliers.
Old Jan 7, 2005 | 10:16 AM
You need to read again. Make sense (note correct spelling)?
Old Jan 7, 2005 | 10:24 AM
Audtatious's Avatar
Bandwagon Lover
What is spelled incorrectly? You've lost me.
Regardless, try again or take it to the dealer if you are inept.
Old Jan 7, 2005 | 10:30 AM
Reading is your friend. Whats the problem there buddy? I already mentioned I used 2 pliers and was asking anyone if they had the same problem. Try posting your "useful information" somewhere else.
Old Jan 7, 2005 | 10:55 AM
Audtatious's Avatar
Bandwagon Lover
You are absolutely correct. Trying to assist someone of your technical level is inane and useless. Obviously, me < reading and you < intelligence.
Old Jan 7, 2005 | 11:01 AM
Uh-huh Perhaps "useful" was too strong a word.
Old Jan 7, 2005 | 02:09 PM
PrinzII's Avatar
OG and counting...
2002: Uhhhhh, perhaps you'd need to chill out!
Old Jan 7, 2005 | 02:29 PM
Cutler's Avatar
Why the harsh words.......?
Old Jan 7, 2005 | 02:44 PM
Lets not just single one person out.
Old Jan 7, 2005 | 02:45 PM
uhhh...how about anyone else?
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
