Changing Fog Light Bulbs on a 2000
Old Jan 6, 2005 | 05:42 PM
DUSTR 71's Avatar
Need to replace a burnt out bulb on my 2000 Maxima SE. How do you get to the bulb to change it? The link in the How To section here does not work.
Help!
Old Jan 6, 2005 | 10:09 PM
mYkEi2KmAx's Avatar
http://www.innerbean.com/housecor/piaa_fogs.html
Old Jan 6, 2005 | 11:32 PM
crispykid717's Avatar
Bigger than Jesus
Something I just noticed about Housecor's write-up is that it is not necessary to remove the screw that holds down the metal retainer clip for the bulb.
Old Jan 7, 2005 | 04:38 AM
DUSTR 71's Avatar
Thanks for the link to the Housecor site. Seems like a lot of work just to replace a bulb!
Old Jan 7, 2005 | 05:12 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
that is actually a write up for a 2k2. the process is actually a little different and more difficult on a 2k/2k1. i had a link posting a how to but it seems to be gone as well.
Old Jan 7, 2005 | 05:28 AM
sarmstrong's Avatar
Help!
I have a 2000 and did this. If you get stuck, PM me.
Old Jan 7, 2005 | 03:23 PM
scmaxima2k's Avatar
Take off the headlight and access the fogs from the top might be easier than taking off the splash guards from the bottom. Just a tip. I haven't personally changed the fog bulbs, just noticed the assembly itself is easy to get to when the headlights are removed.
Old Jan 7, 2005 | 07:29 PM
Maxima2000SE's Avatar
i did it last week. you need to take off like 3 screw bolt things that hold the plastic covers on. after you can see the assembly remove the screw thats on the bottom of the assembly. unplug the connector, twist the cover off, pull the metal clip away to access the bulb, unplug the bulb then pull up on the bulb. Housecors site helped but things were a little different.
Old Jan 7, 2005 | 08:51 PM
XGaSpAcHo
another thing housecor's howto doesn't state is how to disconnect the wiring harness that's attached to the frame. if i remember correctly there should be a little button in the middle that you have to press down the a flat head screw driver and then pull the clips apart.
Old Jan 12, 2005 | 12:39 PM
DUSTR 71's Avatar
Thanks for the tips. I replaced both of them today. Only took about 10 minutes per side. Also rewired them per housecor's tips to come on without the headlights. Worked great!
Old Jan 12, 2005 | 09:22 PM
JayMax2000's Avatar
For guys with the Stillen front lip, can you still get the fog light out with the lip in the way? I want the change mine soon but not sure if I can get them out with the lip.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
