#@!$#!$#@ it..Did anyone else who's replaced the headunit in a 5th gen...
Old Jan 7, 2005 | 06:57 PM
BlueAngel1's Avatar
have trouble getting the !@%$!%$@!# screws out of the stock unit?
I cannot get the damn things to budge.
Any suggestions before I drill them out?
BA1
Old Jan 7, 2005 | 07:03 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
i bought new brackets. Only $16 from Dave B and no headaches.
Old Jan 7, 2005 | 07:06 PM
mistermax's Avatar
start with the ashtray.
Old Jan 7, 2005 | 07:07 PM
03tgtmaxima's Avatar
no i took it out and put it back in in about 45 minutes i had to get back there to see how some wires were ran and it all just came out and back to gether like cake work
Old Jan 7, 2005 | 07:15 PM
silvermax2k2's Avatar
Yeah, it’s easy. But it is not so easy if you don't know what to do. First, take the whole unit out of your car. Bring it in your car, and lay it on its side. Take a sharp object (like a small screw driver or an ice pick) and place it in the screw. Get a hammer, and give a few good whacks. Then do not use a hand driver, use a drill and Phillips bit to take them out. Put all your weight into the drill, and take out the screws. It is that easy. For the suborn screws, tap them with the hammer a few more times, or carefully spray some wd-40 on them. Good luck.
Old Jan 7, 2005 | 07:20 PM
Ka$hThaRipper's Avatar
WOW, and i thought i was the only one who ever had troulbe with this
i ended up drilling right thru the damn screws after i stripped them with a screwdriver and a powerdrill....even tried wd-40 to no avail.
good luck man, and be careful.
Old Jan 7, 2005 | 07:21 PM
i just dont follow you go to yahoo and type in like: 03 maxima sterio removal and you will get a couple sites some good some bad
i found one that was great had arrows and what to watch for some of the things see like they dont want to come out but it will work
Old Jan 7, 2005 | 08:20 PM
BlueAngel1's Avatar
Got the unit out, guys, no probs...it's the headunit from the bracket I can't budge.
GOnna try the hammer tomorrow, and if that don't work I'm demeling the !@#$!%$!@ out.
Or buying new brackets...
Thanks for the help
BA1
Old Jan 7, 2005 | 08:55 PM
Ammi's Avatar
350 Detroit Muscle
That's weird. My screws came right off.
Old Jan 7, 2005 | 09:04 PM
Audtatious's Avatar
Bandwagon Lover
I didn't have any problems removing the stereo itself. I had problems removing the stereo from the bracket when I exchanged 6CD headunits. The screws into the radio were so tight I had to use a phillips bit with a ratchet. They were so tight, I actually broke two phillips bits getting them out!
If you need a "standard" HU removal page, I have one here:
http://www.win.net/audtatious/audio/...remove-HU.html
Old Jan 7, 2005 | 09:09 PM
JPMax's Avatar
What's next!?..
Yeah, a couple of the screws can be a bit hard to get out the first time.
You'll need a large size phillips bit and a power drill. Just lay the whole thing on it's side on a solid table and put your whole weight on it.
Old Jan 7, 2005 | 09:43 PM
Audtatious's Avatar
Bandwagon Lover
My 7.6v Makita worked fine on the "new" head unit. Screws came out pretty easy for the bracket (had to swap climate controls). There was no way my Makita nor 18v cordless could have gotten the other screws out. Nissan must have torqued those babies good!
Old Jan 7, 2005 | 10:38 PM
Ryans Maxima's Avatar
my screws were stuck GOOD too. I used a 1/4 inch ratchet with a scre driver attachment and that did it for me. I was getting pissed though, an hour of almost stripping the screws and I couldn't get anywhere with a reguler screw driver.
Old Jan 7, 2005 | 10:56 PM
dr_redonkulous's Avatar
it took me two hours. a friend held the thing to the table while i used a dremel to cut the slots in the screws deeper. i ended up BREAKING TWO screwdrivers. it was sort of a celebration when we got the screws out. then came drilling new holes into the oem bracket to hold the alpine screen in place. what a pain in the @ss...
Old Jan 7, 2005 | 11:49 PM
whazzzzuup's Avatar
I had the same problem too because I didn't have a correctly sized screw driver bit to unscrew these. I had to drill two of them out because I stripped them but the other two on the other side came out sooo easy with the right sized screwdriver/head/bit.
Old Jan 8, 2005 | 12:30 AM
† ErV †
BA1
Power
Drill
10 seconds tops.
Old Jan 8, 2005 | 07:09 AM
JayMax2000's Avatar
just take a big screw driver put it on the screw and wack the back of the screw driver with a hammer about three times hard, the screws should come rite out.
Old Jan 8, 2005 | 02:47 PM
djfrestyl's Avatar
Suspension Yoda
try tightening them first till u hear like a - tick almost
then undo em with the same screwdriver
come right out
Old Jan 8, 2005 | 03:02 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
you need something with more leverage like get a phillips bit for a socket wrench. a screw driver just doesn't give you that. a big enough phillips tip that'll take the whole opening of the screw, big ones won't slip like small head ones. try that...
Old Jan 8, 2005 | 03:05 PM
adithius's Avatar
My Brother in law messed up 10 of my drill bits getting them out. He has a
5th generation. Just be patient and it will come out eventially. Use common sense. It's a PITA.
Old Jan 8, 2005 | 03:13 PM
LithiuMax
I had a tech at Circuit City use the hammer method. I was worried that I had stripped the screws too much for them to come out, but it was all good after that.
Old Jan 8, 2005 | 07:01 PM
a nice ghetto version of this is clamping the screwdriver at the handle with some vice grips. i was afraid to hit the thing with a hammer. i thought it would damage the headunit... loosen something critical in there ... break something... but it seems that a lot of folks here have just whacked it and it works.
those who hit it with a hammer and screwdriver, anybody check to see if the oem headunit still worked?
Old Jan 8, 2005 | 10:01 PM
nismo_star's Avatar
Came out with 3/8" makita impact gun 9.6v w/ impact philips bit. 10secs
Nissan warranty pays 0.8hrs for R+R audio unit (2k2-3 owners)
I can do it in half the time, so now my service manager gives me all of them
Old Jan 9, 2005 | 09:01 AM
MyownNismo's Avatar
Future Camaro SS owner
That's funny mine where all socket style phillips screws. I got to use a a socket. The ones connecting the brackets to radio where the hardest to get but still came out no problem.
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
Max139617
Aug 29, 2015 02:55 PM
Abdelrhman
Aug 17, 2015 12:16 PM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
