Tranny Flush with Pics
Old Jan 9, 2005 | 06:18 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Tranny Flush with Pics "STICKY" Maybe?????
Done.... Comments and suggestions welcome.......Enjoy
Link below....
Old Jan 9, 2005 | 06:27 PM
S00NR1's Avatar
OU > *
Nice write-up. When I flushed my tranny about a month ago I just went with the flush and didnt drop the pan. But either way is going to help the tranny.
Old Jan 9, 2005 | 06:40 PM
R.I.P. Grandma's Avatar
Very good write up, when i did my tranny flush i had a mechanic use the flush machine which sucks out all the old oil and puts in the brand new.
Old Jan 10, 2005 | 11:46 AM
imported_Max_TL's Avatar
lontar1, !!!thanks from a noob!!!!!!
that's the clearest how-to i've seen on this flush in the forum. i'll be doing mine when it warms up. do you have any pics of what the inside of the pan & magnets looked like? was there much 'gray' material in there?
Old Jan 10, 2005 | 12:00 PM
MrPoisse's Avatar
eum
I see no link in here... am I the only ???
Old Jan 10, 2005 | 12:05 PM
Pasadena's Avatar
Is this the same process with the 5.5 gen?
Nice write up
Old Jan 10, 2005 | 12:40 PM
Originally Posted by MrPoisse
eum
Its in the Cardomain site he listed on the bottom.
Old Jan 10, 2005 | 12:58 PM
03tgtmaxima's Avatar
nice write up man. very clear instructions hey why was the wifey pissed off
Old Jan 10, 2005 | 01:32 PM
& what torque (pounds?) did you do the 21 pan bolts & screen. since you didn't buy the new bolts, is threadtite or a similar product req'd?
Old Jan 10, 2005 | 01:58 PM
Lontar1's Avatar
You don't want to know.. trust me....
Old Jan 10, 2005 | 02:00 PM
Lontar1's Avatar
torque? I didn't have a tourque wrench so I tighten the bolts as hard as I could without breaking the aluminum.......HAND Torque.. so far no leaks....
Lontar1's Avatar
eum
I tried to add the link here but it didn't work... is in the Cardomain page....
Old Jan 10, 2005 | 02:11 PM
ZIPPIN's Avatar
Mauja He Mauja
very nice write-up.
Old Jan 10, 2005 | 02:32 PM
aussie983's Avatar
I don`t think they are supposed to be that tight. Just fairly snug should be okay. Otherwise if u make them all too tight, and you somehow managed to produce some uneven pressure... its likely to leak.
Old Jan 10, 2005 | 02:36 PM
woosh's Avatar
For added tranny flush + cooler info:
http://www.cardomain.com/memberpage/158237/2
http://forums.maxima.org/showpost.ph...4&postcount=23
Update: get the stock tranny clips and toss the ones that came with the super cooler
hope that helps
twin-turbo water-cooled power plant dreams
Old Jan 10, 2005 | 02:37 PM
ZIPPIN's Avatar
Mauja He Mauja
you cannot tighten them, with all your arm power. you will strio them, or they will be a bi@tch to take off next time. i suggest you buy a 20 dollar torque wrench from sears. it will help you a lot
Old Jan 10, 2005 | 03:00 PM
ibag8rfan's Avatar
Is all this absolutely necessary? My tranny fluid needs changing but I was planning on just draining the old and putting the new in, like when changing my engine oil.
Old Jan 10, 2005 | 03:09 PM
woosh's Avatar
I did mine at 15k and the metal shavings was substantial (I drive meduim-hard). It's your car, you know how hard you push it and you know how reliable you want it to be.
You don't have to do a complete flush but in the name of doing one better, you could.
Old Jan 10, 2005 | 03:10 PM
aussie983's Avatar
no a full flush isnt necessary, but you will end up with cleaner oil and you'll probably feel better that gunk on the screen has been cleared off.
Old Jan 10, 2005 | 03:20 PM
CCS2k1Max's Avatar
Good writeup, bad choice of refreshments.
Old Jan 10, 2005 | 03:52 PM
ZIPPIN's Avatar
Mauja He Mauja
if you were a donating memeber, you would not have posted that
Old Jan 10, 2005 | 03:54 PM
looslip's Avatar
Horra!!
When you say "turn the car on", do you mean just turn the key to the "on" position and not crank the starter, or did you crank the starter and turn on the engine?
Also, after draining the ATF in the hose and system, did you add anymore ATF?
Thanks for the writeup.
Old Jan 10, 2005 | 04:24 PM
Lontar1's Avatar
Yes you turn the car "ON"... so the pump will push the oil out the hose...... I will update in the write up.
Yes you have to add oi every time you take oil out... will update...l
Old Jan 10, 2005 | 04:58 PM
Zero Deuce SE's Avatar
Man, I can't believe that you would spend $60 for that Mobil ATF and not spend half that much for new pan bolts. They are supposed to be replaced if you remove them since they are self- sealing bolts. Why take a chance on leaking out your new fluid?
Old Jan 10, 2005 | 05:12 PM
Lontar1's Avatar
Easy answer... I call Dave B and he only had 16.... Icalled my dealers in my area and they didn't have them in stock.. I was supposed to wait another week to get them. In my conversation with Dave B he told me that I didn't need the bolts.....so... I took the chance and so far everything is OK.....
Old Jan 10, 2005 | 07:12 PM
silvermax2k2's Avatar
good write up. If it wasn't winter outside, I would attempt this.. lol.
NmexMAX
May 23, 2016 07:38 PM
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
fx4five
Oct 1, 2015 04:58 AM
