Wierd happening today
Old Jan 11, 2005 | 10:49 AM
Mcrack2464's Avatar
2001 SE Auto w/ 50k mls. Parked the car today--in P not N--went back out to start and got nothing when I turned the key (radio, lights, etc worked but didn't start--no sound when key turned). Let it sit for about an hour, went back out, turned the steering wheel a bit and it started. Anybody have any idea why this happened. It's my wife's car and I don't want her getting stranded somewhere.
thanks
Old Jan 11, 2005 | 11:00 AM
CCS2k1Max's Avatar
Either the neutral safety switch is going or you didn't put the shifter completely in park. Next time it happens, pressing the brake pedal shift it out of park and back in to make sure it makes good contact.
Old Jan 11, 2005 | 12:22 PM
scopium
yea alot of autos have that problem
i found that when this happens just shift it to neutral and it will start..
Old Jan 12, 2005 | 10:11 AM
Mcrack2464's Avatar
thanks for your thougthts on this. If it is a neutral safety switch issue, is that a DIY item.
Old Jan 12, 2005 | 11:11 AM
E55AMG2's Avatar
Wat
Also, check the manual shift lock disengage in front of the shifter to make sure nothing is in it or its not stuck.
Old Jan 12, 2005 | 02:05 PM
OH2kblackMAXX's Avatar
if that happens again heres what to do so you dont have to wait:
-turn the key to the last position, like you were starting it, btu dotn actually start it
-with foot on the brake just move the selector through the gears from P to 1 (doesn't have to be slow or anything, just quickly) and then back from 1 to P
-try to start it again
this same thing happened to me, and thats what i did and do every time it doesn't start and it works fine for me....but let me know if it works if it happens again?
dominic
Old Jan 13, 2005 | 07:12 AM
Mcrack2464's Avatar
Unfortunately that trick didn't work either. Bought a new battery and installed but that wasn't it. Now when I try to start it, I get a "click" and then nothing at all...but lights, etc still work. Anyone else have any ideas?
thanks
Old Jan 13, 2005 | 09:08 AM
E55AMG2's Avatar
Wat
Try pressing in the shift interlock (right in front of the shifter) and starting it.
Old Jan 13, 2005 | 09:25 AM
CCS2k1Max's Avatar
Another thing to try is to wiggle the shifter side to side. Beyond that I give up, I drive a manual...
Old Jan 13, 2005 | 09:30 AM
Kevon1's Avatar
thanks
Probably your starter. Or your alternator one of those two but I would bet its your starter.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
