high flow cat
Old Jan 12, 2005 | 07:26 AM
khynex's Avatar
high flow cat
what would be the difference between this cat and the stock http://cgi.ebay.com/ebaymotors/ws/eB...category=33629
Old Jan 12, 2005 | 07:51 AM
Sammzway's Avatar
The difference is basically with this one you won't pass emission inspection, with the stock OEM cat you will. I'm not sure if you gain any HP tho. Anyway Soonrfan has something like that..
http://forums.maxima.org/showthread.php?t=368931
Read up..
Old Jan 12, 2005 | 08:06 AM
S00NR1's Avatar
OU > *
Hey khynex, you may want to read that guy's feedback before you think about bidding on the product. I did, and I was definitely swayed from purchasing anything from him.
Old Jan 12, 2005 | 08:19 AM
khynex's Avatar
no i wasnt gonna buy it i just wanted 2 know if that thing had any point 2 it
Old Jan 12, 2005 | 01:18 PM
SoonerFan's Avatar
Cletus
that is not a cat..its a straight pipe like i have.
but if it was a "hi-flow" cat then....
three-way catalytic converters on todays cars use a honeycomb structure. they are less restrictive then the older kind that used ceramic beads.
bottom line...the "hi-flow" cats are not much less restrictive then the stock one so i feel that they are a waste of money.
Old Jan 12, 2005 | 01:22 PM
ibag8rfan's Avatar
are hi-flow any less restrictive that test pipes?
Old Jan 12, 2005 | 01:26 PM
E55AMG2's Avatar
Wat
The best high flow cat on the market is the warpspeed metal substrate cat. Flows as well as a test pipe, and will pass emissions in most states. Only problem, its $175
Old Jan 12, 2005 | 01:38 PM
VMaximus02's Avatar
I have that along with the FC's catback and Cattman Y-pipe. I passed emission in Virginia.
FYI: Make sure your car is running for awhile so that the CAT is operated at an optimum temperature.
Old Jan 12, 2005 | 01:40 PM
E55AMG2's Avatar
Wat
i forgot to mention that
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
