6-speed clutch pedal
Old Jan 19, 2005 | 07:38 PM
LA02MAX's Avatar
hey all, i just got my car back from the stealership today.. they were supposed to be working on the cold weather start up noise TSB, but they couldnt re-produce the sound...just my luck...well when i got the car back, the clutch is now considerably different....it used to be REALLY high off the ground and my knee would hit the dash every time i went to put it in...now its nice and low, and i really like how it feels...does anybody else have this problem? also, does anyone know how they fixed it, just for future reference....thanks!
Old Jan 19, 2005 | 07:43 PM
roll4life's Avatar
jus wondering but how many miles are on your car?
Old Jan 19, 2005 | 07:44 PM
Puppetmaster's Avatar
I would actually like to have my clutch "lower" too.... my knee is constantly hitting the steering wheel...
Old Jan 19, 2005 | 07:49 PM
LA02MAX's Avatar
it only has 33000 miles...it has been really high ever since i got it at 30k, and since i was used to a '91 honda accord with a clutch that was about 3 inches from the floor, i noticed it right away....
Old Jan 19, 2005 | 08:18 PM
Derrick2k2SE's Avatar
Here you go.
This came up a few months ago. I did this and it worked fine. You can place the pedal pretty much where you want it. The instructions are for a G35 but it's the same for the Max. On mine I was able to loosten the nut and turn the shaft. Much easier than what they have you do. You'll see what I mean in the instructions. Check it out http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Old Jan 19, 2005 | 08:23 PM
Fezzik's Avatar
You cant just place it where you want. you have to be careful and make sure that it will be completely disengaged when u lift it from the floor. You have to first drive the car in 5th gear and at a certain rpm and speed.
change the clutch and go for a drive and see if it matches. You also have to change the cruise switch and move it foward.
Old Jan 19, 2005 | 08:24 PM
makavelisk's Avatar
Sweet....I am going to have to do this.
Old Jan 19, 2005 | 08:26 PM
Good point... I was just thinking of those myself...
Btw Dave, the y-pipe worked out fine, except for soldering outside in 20 deg weather and for the fact that I broke a bolt and have a leak now... will get it repaired soon though....
Old Jan 19, 2005 | 08:27 PM
LA02MAX's Avatar
thanks a lot derrick and fezzik...i probably wont be doing this any time soon, but just in case it happens again, i will...its a LOT better IMO, and from what i can tell, the RPMs are the same at all speeds and in every gear....
Old Jan 20, 2005 | 05:56 PM
LA02MAX's Avatar
hey everyone, sorry for the bump, but even though my clutch pedal was a little lower, i decided to do what derrick said, and let me tell you, it is AWESOME! the clutch pedal is in such a much better place. It only took me about 25-30 min. to do, and i am not mechanically inclined at all! (in comparison, it took me about 45 min. to replace my foglights!! )
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
