Help!! CF Hood not fitting
Old Jan 21, 2005 | 11:50 AM
dadiesel's Avatar
I went to put my Invader CF Hood on this morning and the bolts in the hood werent aligned. After a little banging and pulling, i managed to barely get the fourth bolt in its hole. But, now the hood will not lock all the way down when i shut it. It latches but wont lock. Any suggestions are appreciated?
Old Jan 21, 2005 | 12:01 PM
crispykid717's Avatar
Bigger than Jesus
You might have to relocate the latch (on the car not the hood). I had the same problem with my CF hood and after relocating the latch it still fit like a$$. Good luck!
Old Jan 21, 2005 | 12:17 PM
dadiesel's Avatar
Do you think its best to just send it back if it's gonna fit like ****?
Old Jan 21, 2005 | 12:19 PM
2kprlmax's Avatar
I would, but first take pictures of the fitment so you have pruf and send it to the company and see what they say
Old Jan 21, 2005 | 12:47 PM
myktek's Avatar
just adjust the latch....move it up higher and it should fit fine....but also make sure there isn't any gaps or anything...... my hood would pop up when i first got my cf hood.....while i was driving....after adjusting the latch, no problems since....
Old Jan 21, 2005 | 12:48 PM
2kprlmax's Avatar
myktek - where did you get your hood from and how much was it. I was looking at the VIS OEM style.
Old Jan 21, 2005 | 01:11 PM
dadiesel's Avatar
So do I have to drill new holes to move the latch?
Old Jan 21, 2005 | 02:04 PM
Bigger than Jesus
I wanted to return mine claiming crappy fitment/product. I also had pics of everything that didn't fit right. The place I ordered it from would not take it back, only give me credit for the hood.
Old Jan 21, 2005 | 02:22 PM
dadiesel's Avatar
I ordered mine from Southwest Autoworks. Do i have to pay for shipping or do they, when I send it back.
Old Jan 21, 2005 | 05:02 PM
MyownNismo's Avatar
Future Camaro SS owner
I have the invader hood.I had same problem yet I can't discribe without taking pics. Since it's the weekend I will take some pics and post here. Try my points and if it still doesn't fit see if you can return it. I didn't modify the hood at all just the car. Also the windsheild washer nozzles are not the right size but I have trick for that too. Give me some time and I will help you out by the end of this weekend.
Old Jan 21, 2005 | 05:04 PM
Ant96GLE's Avatar
On my 4th gen I had to actually drill off a part of the latch so it would lock. It was only about 1/4" but it made a huge difference.
Old Jan 21, 2005 | 05:15 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
my VIS OEM I had to grind down the \ / of the latch right on the front cause it was hitting it and wouldn't wanna shut all the way. What you wanna do is put some WhiteOut on the latch and then close it- this will put some paint on the hood (white out comes off EZ anyways, just scratch n sniff ) and mark the spot where the hood is touching the latch and not allowing it to close fully. VIS is pretty good with hoods thou, wait till you get a Hood off Ebay for a Civic for 250 shipped and try to install it.... I have installed alot of hoods, my VIS OEM fits like a glove after grinding down the latch part right on the front.
Old Jan 21, 2005 | 05:34 PM
myktek's Avatar
the latch itself has adjustments to move up and down....the guy at nissan showed me.....lol....as for my hood, i bought mine through my friend, he needed the money and he originally bought it from VIS...
Old Jan 21, 2005 | 05:38 PM
myktek's Avatar
here are some pics of mine...
Old Jan 21, 2005 | 05:39 PM
myktek's Avatar
1 more....thats all i have that is online
Old Jan 22, 2005 | 08:47 AM
Edward Lee's Avatar
Mytek, what size are your wheels and tires. It looks as though you have a nice amount of rubber. I'll bet your ride is pretty nice and smooth. The car looks great
Old Jan 22, 2005 | 10:09 AM
ibag8rfan's Avatar
looks like 17"s. Looking good.
Old Jan 22, 2005 | 10:18 AM
myktek's Avatar
Racing Hart Type C5 3 Piece
18x8.5 45 offset 245/40/18 1" lip
18x9.5 44 offset 275/40/18 2" lip
i'm pretty sure i have the biggest tires on 18's of anyone on the org... =) ride is ok...not bad....
Old Jan 22, 2005 | 12:40 PM
E55AMG2's Avatar
Wat
Myktek: thats a VIS, right?
Old Jan 22, 2005 | 12:52 PM
Edward Lee's Avatar
Wow what a tire diameter. How much slower is the car and do you have any rubbing issues?
Old Jan 22, 2005 | 03:12 PM
myktek's Avatar
yes it is an OEM VIS hood...as u can tell the only issue w/ fitment is the front....it's kinda high in the middle on both sides of the grille...
it's not that much slower, actually when i get on it, i get more understeer b/c of the traction.....the only prob as far as rubbing is the rear, it rubs that piece of the fender that curves in, thats easily fixable w/ a dremel, but i'm lazy.....
Old Jan 22, 2005 | 04:48 PM
MyownNismo's Avatar
well Blackbird told what I meant but it is the latch but it's where you dremel it down. I also made my latch holes bigger to get it to go down further. It hugs the bumper perfectly. For the windshield nozzles take ones off stock hood place peice of paper of the holes and go over it with a pencil the hole will be lighter. find a way to cut it out and use as template to cut hole.
Old Jan 22, 2005 | 09:02 PM
Triple8Sol's Avatar
I miss the .org!
It's a VIS...what do you expect?
Old Jan 22, 2005 | 11:03 PM
Bigger than Jesus
I thought VIS was a quality product. My hood was not VIS and it was a piece of s#!t.
Old Jan 23, 2005 | 12:31 AM
E55AMG2's Avatar
Wat
VIS makes the best CF hood for our cars. I think the latch problem may only affect the 2k/1s. He told me the exact same thing, but mine fit perfectly with no modification necessary.
Old Jan 23, 2005 | 12:52 AM
A33 VQ30DEK's Avatar
mine fits PERFECT! didn't have any fitment problems, and no hood latch adjustments required.
irvine78 had this hood made from KBD racing.
Old Jan 23, 2005 | 09:16 AM
MyownNismo's Avatar
Yeah and they didn't make anymore which pissed me off since I wanted one at time the where making them.
Old Jan 23, 2005 | 12:40 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
Are hood pins necessary with the CF hoods?
Old Jan 23, 2005 | 02:10 PM
Bigger than Jesus
No, but they are highly recommended.
Old Jan 23, 2005 | 02:40 PM
dadiesel's Avatar
What about when it rains, with the invader or other scoop type hoods? Is it ok for water to go down into the engine?
Old Jan 23, 2005 | 02:51 PM
Bigger than Jesus
Yup. It's no different then when water gets into the engine bay from any place else. But I thought the scoop on the Invader hood didn't actually leave an opening into the engine bay? Isn't it just for show? Someone correct me if I'm wrong please.
Old Jan 23, 2005 | 04:02 PM
MyownNismo's Avatar
It's a opening. There's a grill there. water would fall between radiator and engine. No worries.
Old Jan 23, 2005 | 08:05 PM
I had a KDA hood before, and it wasn't CF, it was Fiberglass with a coat of CF over it. It flexed like crazy and if you didn't have hood pins it looked like the hood was going to fly off the car. Doing 70MPH on the highway even with hood pins the hood would BOW UP in the wheel arch area and looked nasty. Some .org member a while back insulted me for being a riceboy by having hood pins- without these I wouldn't have a hood very long. VIS on the other hand DOES NOT need hood pins. I have had mine for hmm like 6 months now and it doesn't move a bit, its even CF under the hood in the latch area. I have pics of the KDA hood on my computer, the latch looked like ****, and so did the rest of the hood. I got it from CustomMaxima.com through a group deal they had a loooooong time ago, I got my hood and they cancelled everyone elses order as they found some kinda flaw in them or something like that. VIS makes the best CF hoods.
Old Jan 23, 2005 | 08:13 PM
sooner02r1's Avatar
You should get some freakin' huge, chrome hood pins, and then still use your latch so the hood pins are doing nothing. That would be sweet
Old Jan 23, 2005 | 08:23 PM
big round hoops like they stick in BULLS nose at the rodeos ! Thats what I want on my hood, plus some bull horns like the Enis Brothers had on their Eldorado in Smokey N the Bandit
Old Jan 23, 2005 | 10:11 PM
my hood pins are the only thing keeping my hood from flying up. HOOD PINS are AWESOME!
Old Jan 24, 2005 | 01:18 AM
Triple8Sol's Avatar
I miss the .org!
VIS is not that great at all. Way overrated among Maxima owners.
Old Jan 24, 2005 | 01:08 PM
MyownNismo's Avatar
I would like fiber image to make one for us.
Old Jan 24, 2005 | 05:57 PM
dadiesel's Avatar
I got home from work yesterday and my girlfriends dad had my hood on and fitting perfectly (took her car to work). I think it looks really good! The upper and lower grilles, and the black housing of my projectors, make it look even better. The only problem is that i just have two rubber hoses sticking out of the hood because I couldnt get the old washer nozzles out. Any suggestions on how to get them out or where to buy new ones (that arent chrome)? How do I get pics up in a thread?
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
Pied
Sep 26, 2015 03:29 PM
