How hard is the installation - is it something I can do myself or it requires a body shop mechanic?
Did you guys fit it on first since I heard it comes in weird shapes or paint it then install?
I'm getting the full kit for $700, $100 off the website price, so I guess I'm getting a good deal.
I can tell you about the front lip...it does come all bent up BUT do not get freaked out, just set it under some heat for a few hours and it will go back to it's shape. Install-2 screws on each side and some 3M double-sided tape will do the trick.
it is easy enough. It's even more easy if you have a friend to help you out. no need for a body shop unless you want it "molded"
you should be fine.
you should be fine.
