rear tail light conversion problem
i have a 2000 but replaced red lights for 02 clear/yellow, but stock blinker bulb and plastic piece that holds bulb will not fit in housing of 02 tails. tried to get a diff bulb but still plastic piece too large to screw into back of light housing. any suggestions? also need oem 02-03 grille for new bumper. thanks
'02 T/L conversion
I just installed my '02 T/L's on my '00 SE this morning. As long as the tail lights you're putting on has the harness on it, you're ok. If you're just getting the housing, with no wiring and bulbs, then you need to purchase that from Nissan, of a junkyard. The install took only about 20 minutes. Very easy to do. And yes that sealant is a pain in **** to separate the light from the body. I used a flathead screw driver and pushed through the sealant. Gotta love the look of thosT/L's on a white Max!
yeah the sealent was tough but i managed, and they do look so good on the pearl white, but only on the light colored cars. they really look bad and out of place on the dark colored cars, i'm surprised nissan did that. i think the 01 se tails look better on the dark even if it does mean downgradeing to a older year tail light. anyway i bought the 02 front nose and am looking for a stock 02=03 grille as well, if anyone has one. thanks for all the help, pasquale
Ok I open the box to find that it(harness) was aready there. I went the dealership and that part that the bulbs twist in to can be used from you "00 tail lights it has two philps screws and two tab holding it on. Use that part for your "00 lights it fits directly in to the "02 housing. This way is the cheapest and simplest way not to buy that harness. It only cost $24 at your local dealer
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
220k+ A32
Aug 17, 2015 03:57 PM
