Order of stiffness of springs??
Old Apr 27, 2001 | 12:04 PM
Keh mon's Avatar
hey I've done some research and a bunch of reading, but which springs are stiffest and which ones are softest? the ones that I know that fit our 5th gen are
Eibach
H&R
Progress
Sprint
B&G
Intrax
I know how low each one will make the car, but just unsure of stiffness... thanks for the help!
Old Apr 27, 2001 | 12:05 PM
punkdork's Avatar
I'm running eibachs, they're supposed to be stiffer than the H&Rs.. Sprints I've heard quality concerns.. the others?
Old Apr 28, 2001 | 12:58 AM
Wustylez
Eibach
H&R
Progress
Sprint
B&G
Intrax
Well, law of physics says that the lower you go , the higher the spring rate it has to be in order to hold up the weight of the car!!!
So go figure!!!
But, ppl say that Eibach are stiffer than H&R which could be true if the spring rate is confirmed...H&R is usually 25-30% stiffer than stock, same as B&G!!!!
But B&G drops more so, it has stiffer feeling ride for sure!!!
Tim
Old Apr 28, 2001 | 12:40 PM
Daniel Ralston's Avatar
Nope the laws of physics don't say that. The lower you go the stiffer you *want* it to be so that you don't bottom out. There is no reason you can't have any stiffness at any height for any weight.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
bigfrank
Oct 1, 2015 12:51 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
