E-Brake locking up! How-to Adjust?
Old Jan 29, 2005 | 07:29 AM
SurrealGTI's Avatar
Sup fellas..
Since the cold weather, problem is when I leave the emergency brake on for a few hrs or overnight and after I release the handle down it seems to still lock up the rear wheels. After about 5 min of driving, it appears to fully release it. What do you think the problem and solution is? My guess is the parking brake just needs adjustment. If so, how to please.. thanks!
Old Jan 29, 2005 | 08:03 AM
kratz74's Avatar
DOnt use Ebrake in the winter....
Unless you are on a huge hill, you don't need it. Just put in in park or for a manual, reverse or 1st. and you are fine. If you are on the street turn your wheels so the car if rolled would gently rest up against the curb.
Old Jan 29, 2005 | 08:27 AM
hct67's Avatar
Is there anyways of getting some lube inside the E BRake line so it won't freeze up. Yesterday I put it on for about an hour and well the rear wheels were locked up!!!! I have a 6 speed and also I have a remote start so I need that E Brake!!
Old Jan 29, 2005 | 08:45 AM
Zero Deuce SE's Avatar
If you live where they put down salt when it snows, your cables are probably rusted and are hanging up. WHen the cables rust severely, they swell up and cause you problems in applying and reeasing the parking brakes.
Old Jan 29, 2005 | 05:12 PM
SurrealGTI's Avatar
Thanks for the suggestions guys but does anyone know how to adjust the parking brake? In addition to the locking, the parking brake doesn't seem to hold the rear wheels very well when I tested it. Thanks in advance!
Old Jan 29, 2005 | 09:18 PM
young1976's Avatar
I think there's bolts underneath the arm rest/center consul
Old Jan 30, 2005 | 06:20 AM
Originally Posted by SurrealGTI
Sup fellas..
What year and model is your car?
Old Jan 30, 2005 | 08:10 AM
Ammi's Avatar
350 Detroit Muscle
I've never had e-brake freeze up on me. I've used it everyday for 4 years. I've heard that if you don't use it often, they will freeze up.
Old Jan 30, 2005 | 10:44 AM
SurrealGTI's Avatar
2002 Maxima GLE Auto
Old Jan 30, 2005 | 11:29 AM
Check your PM box.
Old Jan 31, 2005 | 05:54 PM
MiniRX7's Avatar
I had this problem on my 2k3... TOok it to the dealer, they replaced the parking brake cable.
At firsth they thought, Caliper, so the changed that, but it was the cable. NO problems since.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
