home link controls (garage door opener)
Old Jan 30, 2005 | 09:18 PM
xxdean057xx's Avatar
is their any trick to setting the program. i tried the way in the instruction manual but it still wont work. anyone else have this problem?
Old Jan 30, 2005 | 09:22 PM
3x10^8's Avatar
I, too, have tried and failed to set the code correctly per the instructions given. And I haven't the slightest clue as to how to go about it. Sorry!
Old Jan 30, 2005 | 09:25 PM
Charliejag's Avatar
same here, I think my countless wiring projects have messed it up. I haven't had a chance to dig in and figure it out but if I do I'll post a thread about it.
Old Jan 30, 2005 | 09:31 PM
Kevin's Avatar
you need to follow the rolling code programing procedure. check out www.homelink.com
you follow the normal procedure and there are a few other steps after that which require you to push the button on the garage unit itself.
Old Jan 30, 2005 | 09:32 PM
Puppetmaster's Avatar
that's what worked for me...
Old Jan 30, 2005 | 11:55 PM
ThunderMaxi's Avatar
If you have a rolling code garage door opener, you have to press it 3 times once you click the button on the garage door opener itself. That's what messed me up. FInally after 4 years of living at my house, I got it done. 2 people doing it would help.
Old Jan 31, 2005 | 11:28 AM
Klutch's Avatar
I had some problems with my rolling code opener as well. Once I finally realized that you first have to program the remote in the visor to be a compatible remote and then sync it with the opener I was fine.
Old Jan 31, 2005 | 02:35 PM
tedsmax's Avatar
The only problem with this is that you are programming your garage door opener with a non-rolling code device. This means that someone could read the signal and use it to open you door. Granted, the chances are pretty slim.......
Old Jan 31, 2005 | 02:47 PM
Gsilk's Avatar
Reported
the manual should have instructed you if you do have the rolling code feature. in any case, i would recommend two people to help set it. My dad needed a ladder to reach the garage door unit while I pressed the button on the visor.
Old Jan 31, 2005 | 05:32 PM
hmmmm.......... still does not work for me. the light turns solid so i guess its supposed to be programed already, right? after all that it still wont open the garage door. thanks
Old Jan 31, 2005 | 05:57 PM
bladerunr's Avatar
Try it again. I followed the instructions and it didn't seem to work at first, then for some reason it did. Not sure what happened, but didn't question it. 2 people are nice but you can do it with 1.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
Gildarts
Aug 31, 2015 07:10 AM
shaunkey1
Aug 18, 2015 10:09 PM
