Any 5.5 gen auto w/ TS ecu?
Old Jan 29, 2005 | 09:52 PM
Shogunsc4's Avatar
Anyone on here with a 5.5 gen auto got the technosquare ecu? I was wondering if the reflash helps at all. Recently ran w/ my boss's '92 NA 5speed 300zx from a 50mph roll and I wasnt impress w/ my max. I took off by a car but by ~90mph he caught up to my front fender and we both shut off. It felt like my 2k3 auto has NO top end and alomost lost to a STOCK VG30. I'm seriously considering the reflash. anyone w/ firsthand experience?
Old Jan 30, 2005 | 06:15 AM
03BlkSETE's Avatar
juice and blubyu both had it done. No gains were made for the auto. I might be worth getting the L-Spec version which raised the rev limiter and eliminates the speed limiter.
Old Jan 30, 2005 | 07:18 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
are you throwing any codes at all? i am not attempting to turn this into nissan on nissan violence but my 2k1 has not had any problem running 300zx in either auto or 5spd. i have run a few modded NA VG and they might get a jump off the line from dumping the clutch but i have been about to reel them in and put a good bit of distance even before 90. i am not attacking your or z cars but maybe you should run another 2k2 auto and see if you can keep up. on another note, unless another version of the auto programming comes out then follow 03BlkSETE's advice of getting the l spec. blu dynoed no difference besides having the raised limiter.
Old Jan 30, 2005 | 07:57 AM
joebangaa's Avatar
^^ really.....i thought kloogy really liked his?? so NO power gains for auto???? that is a shame seriously. and yea i think NA 300zx's are slower than they should be for some reason
Old Jan 30, 2005 | 08:24 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Years ago I ran my friends 96 2 seater 5spd 300ZX at Phoenix International Raceway in my 93 SE-R with just Place Racing CAI, HS header, Greddy SP exhaust, and I would always whopp on him by 2-3 cars by the end of the 1/4. He would run 15.1s-15.4s stock and I would always get by him with 14.6-14.7s on street tires. He knew how to race n all, I'm sure my Max would slaughter a NA Z. My friend was so impressed with the SE-R, he bought 2 of them after that. Once a you drive one, you will understand.
Old Jan 30, 2005 | 08:30 AM
MaximaPolak's Avatar
But since it makes the redline higher, there would be more power at the wheels after an auto shift. WOULDN'T THERE?
Old Jan 30, 2005 | 08:58 AM
03BlkSETE's Avatar
I'm not exactly sure of what you are saying but I'll take a guess. The answer all depends on where your power band is and what rpm you land at after a shift. It's certainly possible that with mods that raise your power band higher up the rpm scale a higher redline can help. I seriously doubt that it would have any positive effects on a stock or mostly stock vehicle. Like I stated in my first post, if you are mainly looking to move the rev limiter to 7200 rpm, you should get the L-Spec version of the reflash which is less expensive
Old Jan 30, 2005 | 09:14 AM
Nismotech1's Avatar
confident nissan owner
ok i've seen dynos for stock 5th gen autos vq30 and on the ones i've seen the hp increases all the to redline so even in an auto with light mods you will see a power gain (atleast with the vq30 k ) if you increase your redline.
Old Jan 30, 2005 | 09:21 AM
SR20DEN's Avatar
VQ Wizard
I keep asking for this info to be made a sticky. 90% of the people that want to buy a TS ECU should ONLY get the L-spec from Technosquare.
Old Jan 30, 2005 | 10:19 AM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
Has anyone seen a dyno from a 02-03 maxima with proven gains??? If so please show it on here.
Old Jan 30, 2005 | 12:02 PM
joebangaa's Avatar
let's clear up the confusion in the air shall we?
Old Jan 30, 2005 | 05:34 PM
sloppymax's Avatar
blu has his dyno hosted somewhere but im trying to contact the person hosting it so i can get the address. as soon as i can get my hands on, ill link and show the no gains claim.
Old Jan 30, 2005 | 09:26 PM
E55AMG2's Avatar
Wat
I picked up 9whp and 11wtq (I was the donor car)
Old Jan 30, 2005 | 09:30 PM
joebangaa's Avatar
^^ that's what i thought.....and you were stock correct??
E55AMG2's Avatar
Wat
This is correct, unless you know how to tune engines
Old Jan 30, 2005 | 09:32 PM
E55AMG2's Avatar
Wat
Yes, 100% stock except for a PT1012 muffler. Muffler alone made 0 gains (except noise), dyno tested.
Old Jan 30, 2005 | 09:34 PM
joebangaa's Avatar
and then did you retune it since you got headers or no?
personally i'm not worried too much cuz TS is like 30 min away from here
Old Jan 30, 2005 | 09:37 PM
E55AMG2's Avatar
Wat
DO NOT....I repeat....do NOT tell TS you are modded. Just ask them for an ECU flash upgrade for a stock max. Those perform the best. They dont seem to know how to tune correctly for mods.
Old Jan 31, 2005 | 06:29 AM
juice's Avatar
As others have said before...JUST GET THE L-SPEC....there are no gains from the tuned ecu reflash
Old Jan 31, 2005 | 07:28 AM
NmexMAX's Avatar
dot dot dot ...
E55AMG, are you auto or 6M?
Old Jan 31, 2005 | 08:37 AM
bgates1654's Avatar
http://forums.maxima.org/showpost.ph...1&postcount=12
Mine is a 6spd though.
Also for track times:
http://forums.maxima.org/showthread.php?t=352176
Thats with a full spec TS ECU tuned for an intake and catback exhaust. As an auto I, like everyone else, would suggest you get the L-spec ECU. If you want to do fuel tuning get the SAFCII. If you want to do that and ignition timing get the greddy emanage or the SMT7.
Old Jan 31, 2005 | 08:59 AM
SR20DEN's Avatar
VQ Wizard
Can you send me your run files?
Old Jan 31, 2005 | 09:20 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If he can't, I have them somewhere SR.
Old Jan 31, 2005 | 10:06 AM
E55AMG2's Avatar
Wat
Auto...
Bgates: you cant advance the timing correctly with either of those units....
Old Jan 31, 2005 | 11:00 AM
NmexMAX's Avatar
dot dot dot ...
We all know the 6spd show gains, but the only auto I know making gains w/TS ECU is E55AMG2, and that seems to be a rare case. . .
Old Jan 31, 2005 | 11:15 AM
IceY2K1's Avatar
What do you know in regards to the SMT7?
Originally Posted by E55AMG2
Auto...
Old Jan 31, 2005 | 01:09 PM
bgates1654's Avatar
SR20DEN, yeah I can send em to you sometime tonight.
Hmm problems advancing timing with those units? Would you be able to give detailed info as to whats up with that or perhaps point me in the right direction so that I can find it myself?
Old Jan 31, 2005 | 01:19 PM
SR20DEN's Avatar
VQ Wizard
The SMT7 and SMT6 don't intercept the timing the same way that hte eManage does. And currently no one has even tried the SMT7 to even know that it works or not. I believe it will work.
Old Jan 31, 2005 | 01:30 PM
IceY2K1's Avatar
The SMT6 supposedly allows advancing timing unless you guys have heard otherwise....
eManage can only retard, since it's controlling the ignition OUTPUT and it can't guess before firing what the timing will be. SMTX intercept the INPUT to the ECU, ie crank/cam sensor, so it can fool the ECU into firing earlier/later as long as the ECU doesn't notice and throw codes.
Old Jan 31, 2005 | 02:33 PM
E55AMG2's Avatar
Wat
Obviously, not as much as I thought....
Old Jan 31, 2005 | 02:38 PM
NmexMAX's Avatar
dot dot dot ...
From the TS website, the L spec is said to reduce the throttle flap closing during high rpm for increased power. I however find this to be hard to believe. Has it ever been proven to close?
I've heard of stories of other cars with TBW that the throttle is said to close slightly during shifts to make them smoother.
Has any of this been tested, and if so, proved to be true when upgrading to the TS l spec reflash?
I've called TS before regarding an ECU update, but they always ask for the modlist of my car and state to me that if not done with relation to my mods, the car will not run right, but E55 suggests that telling them that your car is untuned seems to be the best outcome.
I remember juice and Blubyu2k2 reporting that they saw no gain on the dyno or track whatsoever besides the rev limiter. And juice also states that he gets no better times when shifting at 7k or 6.5k.
I also remember reading where someone finally got TS to admit that they just used the same parameters as the 6spd version but for some reason couldn't get any gains on the auto from it, hence the offering of the L spec, and I also remember reading that some TS ECU's did not even have the rev-limiter option enabled when requested.
Another observation of mine is this : I have both a 4g and a 5.5g, when the 4g is in stock ECU mode, it seems to limit at about 6.6k, but pretty strictly around that area, as indicated from the tach, which I know sometimes tends to be off by a small margin, but still seems not to go past 6.6k. As opposed to my 5.5g which goes freely to ~6.8-6.9k, at first I was curious and thought, as I bought my car used, maybe it had a TS, but after much thought and consideration and after meeting the previous owner of the car, I finally ruled out that option(oh yeah i checked the ECU too, and no TS marking of any kind was found), as it would not go to the TS claimed 7.1k. My thoughts would be, does the 5.5g ECU let the revs go further before fuel cut, or is the tach off by a larger order as compared to the 4g?
Is the reflash really worth 365 dollars for only 300 more rpms because that's essentially what the gain is, from my POV.
Old Jan 31, 2005 | 02:55 PM
SR20DEN's Avatar
VQ Wizard
Just look at the end of my dyno chart. And that isn't the only place it limits throttle. I personally proved one of the choke points even before Cheston had TS crack his ECU.
Old Jan 31, 2005 | 02:57 PM
bgates1654's Avatar
my earlier dynos showed that at 6600rpm i was really at 6200-6300. In my dyno wiht the ECU I crank it out to 7000rpms on the tach and it shows up as 6700-6800 on the dyno. I have hit the rev limiter once and on the tach it showed about 7500rpm. So in conclusion the tach is off... atleast mine is.
Old Jan 31, 2005 | 03:10 PM
E55AMG2's Avatar
Wat
youre not alone bgates.....alot of ppls are (mine is ~400 off).
I think blu and juice both told TS their modlist and neither showed gains. I told them I was stock and i picked up 9whp and 11 ft-lb. That suggests their tuning is not quite the best.
As for the extended limit, my times dropped due to the fact that I got past the 1-2 shift dead spot @40mph (shifts ~53mph). However the drops in time were about .2sec
Old Jan 31, 2005 | 03:15 PM
IceY2K1's Avatar
4g, 5g, are 6400rpm
5.5g are 6600rpm
Nissan tachs are lazy SOBs, so don't believe what you see on them.
Old Jan 31, 2005 | 03:16 PM
IceY2K1's Avatar
Now that you have the rod bolts in, when are you going to get the L-spec program?
Old Jan 31, 2005 | 03:22 PM
steven88's Avatar
Need A Light?
my stock tach is off for sure....I've hit 6800-6900 many times indicated on the tach till it bounces back....so i'm off by 200-300rpms...
it's kind of cool though....i took my friend out for a drive with my APEX-i/BERK....and i told him to watch the tach swing passed 4k (VI kicks in)....then i pegged the needle all the way to 6900 or so and switch real quick....and he was like daaang that sounds crazy! and i told him....i have a raised rev limiter to 7500 and he believed me....lol
Old Jan 31, 2005 | 03:26 PM
NmexMAX's Avatar
dot dot dot ...
The limiting throttle theory has been proven, but what about on an auto, I would hope it would be the same outcome. But typically autos don't prove this, why?
Another observation of my 5.5 vs 4g is that even though it would be safe to downshift at a certain speed, it(5.5g) still insists on going with the next gear and noticeable limiting throttle opening which is characterized by a pretty large surge in power after the car has finished completing it's downshift, even though it had been WOT well before the downshift was initiated.
I know Juice has a picture of his dyno, I'm sure it's somewhere here, forgive me as I haven't looked around for it very thoroughly.
From what I've seen, what seems to be typical VQ35 output is to become a little wheasy at high rpms, despite the VIM as well as breathing mods, (I/H/E). Is this high RPM power loss directly linked to the Ethrottle limitations?
Old Jan 31, 2005 | 03:32 PM
NmexMAX's Avatar
dot dot dot ...
That would make sense, as ECU tuning, in the realm of no-so-radical tuning (i.e. no presence of F/I) modifyng for a "stock" Maxima would seem reasonable, as most bolt on mods won't requrie too much further ECU tuning, which would suggest that maybe TS is "over"tuning for normal bolt on mods.
Old Jan 31, 2005 | 04:19 PM
joebangaa's Avatar
krmaxima got gains stock auto...he said he dynod 210whp after, don't know if he had a baseline...CLEAR YOUR PM BOX lol
