Headlight Situation
Old Feb 2, 2005 | 07:29 AM
TaLoN2 20's Avatar
Headlight Situation
hey guys, i'm a member over on altimas'net so i knew about this site. A friend of mine ordered a set of projector headlights for his 2000 maxima. The question i have is, his stock headlights only have 1 bulb for the headlight, then another for the blinker...as far as i know. The new headlights have 2 headlight bulbs...or at least a headlight and an angel eye. I would assume his stock harness will would need another bulb to fill the new set. Whats the easier way to hook it up. P.S. i could be totally wrong about his stock harness, but i'm just guessing. hopefully someone can help me out. Thanks in advance fella's
Old Feb 2, 2005 | 12:19 PM
TaLoN2 20's Avatar
^^^ bump. someone's gotta know here...jeeez
Old Feb 2, 2005 | 04:55 PM
mattattax's Avatar
I don't know anything about the lights----but I'll bump the thread.
Old Feb 2, 2005 | 05:07 PM
under5295's Avatar
it dont matter that the new projectors have two bulbs the pluugs do straight into the factory ones
Old Feb 2, 2005 | 05:08 PM
ChromeSE5's Avatar
plug and play. uses h3 for projectors (yuck) and h1 for highs. 194 for corner lights
Old Feb 2, 2005 | 05:55 PM
ColdSHO's Avatar
yeah the stock h4/9003 bulb connectors have three connectors for the high low funstion, so in a way its almost liek 2 bulbs in one. two filiments. so it all works out.
Old Feb 2, 2005 | 07:12 PM
Raf2kMax's Avatar
i heard HID's dont fit in the projectors for the 2k-2k1 maximas? you have to somehow retrofit them in? what's the deal with that? anyone know?
Old Feb 2, 2005 | 07:15 PM
under5295's Avatar
thats a bunch of bull!!! They fit you just have to have the right bulbs like the H1 & H3s
Old Feb 2, 2005 | 09:33 PM
ChromeSE5's Avatar
HIDs will fit; you will just need to rebase the HID bulb to fit the H3 socket. The light output is better than just using the h3 halogen bulb.
It is strongly suggested to use HID projectors though. The projectors should be replaced with valeo or phillips HID projectors. That retrofit can be expenisve though; ballast, igniter, projectors, bulb, harness, and whatever else I forgot to mention cost around $430.
Dr.Roy has done an MDX retrofit on his projectors and the cut-off line looks pretty sharp. He used halogen projectors but it seems they can handle HID. After modding the projector, he got pretty good color.
Try to look for his cardomain, he has a write up.
Old Feb 2, 2005 | 09:46 PM
JayMax2000's Avatar
what does it mean to rebase the HID bulb. I'm planning on doing HIDs to mine pritty soon.
Old Feb 3, 2005 | 12:08 AM
ChromeSE5's Avatar
HIDFORUM.com
I was planning to do this. It allows for the d2s bulb to fit into certain sockets like h4, h3, h1, etc. Unless you buy a kit that specifically comes with a bulb to fit the h3 socket, you'll have to change the base of the bulb. This comes into play if there are bulbs for sale or if you want to change your HID color (from lets say 5000k to 6400k)
i havent had any experience hands on but i have been seriously reading hidforum.com because I am looking to do the retrofit. here is the noob section of thier forum.
http://www.hidplanet.com/forums/viewtopic.php?t=2080
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
