Need help with this-start up problems...
Old Feb 3, 2005 | 04:25 PM
PTP's Avatar
PTP
What could be the possible cause of this:
On cold starts, usually at the beginning of the day(morning), I start the car, then after about 1 min the RPMs begin to drop down. When they get to below 1000 the car shuts off. IF I hit the gas to rev the engine, hence increase the RPMs, it won't shut off. ONce warmed up, none of this happens and the car is fine.
Is this something major or just carbon buildup somewhere?
Old Feb 3, 2005 | 06:25 PM
PTP's Avatar
PTP
anyonee???
Old Feb 3, 2005 | 06:31 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
look in the forum for fourth gens. I have the same problem. seems theres a fsb on cold starts in the 97-98s, ill see if i can find the link again.
Old Feb 3, 2005 | 06:35 PM
Chocolate_Boi_1Der
FORUM POSTS
Starting and Charging (Battery)
EGI Wire Harness Breakage Diagnosis And Repair Procedure
Cold Weather Starting Tips
Hard/Slow Cranking - Diagn - Ecm
Drivability And/Or Chk Eng Light On -DTC 45 Inj Leak
Crank - No/Hard Start
Intermittent No Start
Intermittent No Start - No DTC's
Reman Starter/Alternator Program
Go down to this section and go to the appropriate one.
PAREDLINE
May 9, 2006 11:21 AM
hott_nikkelzz
Apr 12, 2006 09:16 AM
2maximas
Jan 23, 2006 01:22 PM
mtrai760
Aug 13, 2002 09:02 AM
djslinkyz
Oct 19, 2001 01:34 AM
