question on our strut bars
Old Feb 4, 2005 | 09:36 PM
OutMaxxed's Avatar
How much torque should i use to tighten the strut bar with?
Old Feb 4, 2005 | 10:34 PM
sooner02r1's Avatar
I have heard 22psi, but I went with whatever housecor said on his website, it was in nm, I don't remember how much, but his website is www.innerbean.com/housecor and it's under the suspension install writeup. It will tell how much to torque down the strut towers. What kind of strut bar did you get?
Old Feb 4, 2005 | 11:02 PM
limsandy's Avatar
psi is a unit for pressure. The strut bar should be tightened to about 30-35 Nm, IIRC.
~limsandy
Old Feb 5, 2005 | 01:26 PM
Puppetmaster's Avatar
Yeah, I believe its around 35 lbs of torque.... or Nm... whatever the right unit is...
Old Feb 5, 2005 | 01:48 PM
Ammi's Avatar
350 Detroit Muscle
20 some pounds I believe
Old Feb 5, 2005 | 02:04 PM
From Housecor's site:
Use the following torque specs in newton meters (N-m):
- strut to steering knuckle bolts 140-159 N-m
- strut upper mount nuts 39-54 N-m
Old Feb 5, 2005 | 03:04 PM
crispykid717's Avatar
Bigger than Jesus
I believe I used 35 on mine.
Old Feb 7, 2005 | 03:04 PM
OutMaxxed's Avatar
my 00 max has a bracket where the stut bar mounts. Now do i mount it on top of the bracket, under the bracket, or take out the bracket entirely?
Old Feb 7, 2005 | 05:35 PM
spring02's Avatar
Got a pic OutMaxxed?
Old Feb 7, 2005 | 05:44 PM
OutMaxxed's Avatar
sorry no pic but the bracket im talking about sits right under the 3 bolts on top of the strut mount. Its black..
Old Feb 7, 2005 | 06:00 PM
irish44j's Avatar
retired moderator
no, you take out the black metal bracket, as I recall.....else the bar won't fit.
Old Feb 7, 2005 | 07:58 PM
spiromax's Avatar
Seoul Man
For all of us non-metric guys:
1 Nm = 0.7376 lb-ft
So 35 lb-ft is equal to 47.45 Nm. Housecor's site recommends 39-54 Nm for the strut upper mount nuts, so 35 lb-ft fits within that range nicely.
Old Feb 7, 2005 | 10:00 PM
housecor's Avatar
Guess I should've stuck with good ol' ft. lbs. BTW - These figures are pulled straight out of the Haynes manual if you want to hit the local library/auto parts store.
Old Feb 7, 2005 | 10:33 PM
lex3015's Avatar
yeah i think on mine i took out the metal bracket or else it wasn't gonna fit..... can't quite remember though. i'm sure you'll find out when u do it
Old Feb 8, 2005 | 08:00 AM
1 Nm = 0.7376 lb-ft
Thanks for clearing that up.... I just remembered it was 35 something...
Old Feb 8, 2005 | 12:06 PM
OutMaxxed's Avatar
thanks for the feedback everyone
matts95max
Apr 23, 2025 10:44 AM
t6378tp
Sep 29, 2018 04:27 PM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
