Windshield Nozzle
Old Feb 7, 2005 | 03:31 PM
FanaticMadMax's Avatar
Windshield Nozzle
I'm just having a problem with my driver side spray nozzle. It stop spraying, the passengner side works fine. I thought maybe i'm low on washer fuild. When I filled it, it was nearly empty. Now I tried it again to see if it spraying and the driver side is still not coming out anything. I check the nozzle see if it's clogged or something, the hose, everything seem to be in order. Does anyone have that same problem? Where else should i check for?
Old Feb 7, 2005 | 04:21 PM
MaximaPolak's Avatar
did you look if it's connected?
Old Feb 7, 2005 | 05:17 PM
art-e's Avatar
Try clean it, It's pluged with dirt.
Old Feb 7, 2005 | 05:53 PM
skierxx5556's Avatar
yeah i had the same problem it must have been cloged with something because it didnt work for a little while then one day it just started working again so i would suggest eaither cleaning the nozzle or holding the spray switch for a while and see if that does anything.
Old Feb 7, 2005 | 06:57 PM
nismo0604's Avatar
stick a pin in the nozzle
Matt93SE
May 24, 2019 02:58 PM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
DZN13
Aug 24, 2015 11:00 AM
jchronis2552
Aug 13, 2015 07:48 AM
