Steering wheel still shaking......:(
Old Feb 10, 2005 | 02:44 AM
skyjay617's Avatar
problem before:
steering wheel was shaking during high speed braking.
solution before:
front rotors were bend, replaced for new ones, problem was gone!!
problem now:
after about 2k-3k miles of the new rotors, steering wheel started shaking again during high speed braking and i could hear the very deep braking sound
sloution now:
could be the pads??? or rotors again??? or something else??
thanks
Old Feb 10, 2005 | 04:16 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
If the rotors a new "factory" it could be that they are bent .....but that's a major problem with the Max rotors.. if you look at them the will bend........ Also it could be Balancing...try balancing the wheels... that should help...... but if the shaking continues.... replace the rotors with PowerSlot.. they worked for me....
Old Feb 10, 2005 | 04:18 AM
SoonerFan's Avatar
Cletus
im gonna go with wheels needing to be balanced
Old Feb 10, 2005 | 05:45 AM
spirilis's Avatar
yikes
it sounds like your rotors warped again, that's no good...
Try re-tightening your lugnuts with a torque wrench? Maybe they're overtorquing or torquing the lugnuts unevenly (doing some tight, some loose, etc.)...
If the wheels haven't been balanced lately OR you haven't had an alignment recently, get both of those done.
Old Feb 10, 2005 | 07:37 AM
ddh1313's Avatar
Did you reuse the old pads when you replaced the rotors?
Old Feb 10, 2005 | 08:10 AM
Ammi's Avatar
350 Detroit Muscle
Probably not because problem came after 2k-3k miles
Old Feb 10, 2005 | 09:19 AM
spiromax's Avatar
Seoul Man
Wasn't there a TSB regarding this problem? The rotors on our cars warp easily, but I remember somebody saying that the hub the rotors are attached to may actually warp, which causes new or newly machined rotors to warp more quickly than they should.
Old Feb 10, 2005 | 10:07 AM
young1976's Avatar
Never heard that before. The hub face warped? Hub face is thicker than the face that the lugs go through on the rotor. I doubt that the hub is warped.
Old Feb 10, 2005 | 10:23 AM
ddh1313's Avatar
This is the TSB: http://apollo799.50megs.com/Maxima/Brake%201.htm
It does not mention the hub being warped however one can only speculate so many causes as to why Nissan would call for an on-car vs off-car lathe.
Old Feb 10, 2005 | 02:44 PM
skyjay617's Avatar
yes i reused the old pads after i replaced the new drilled slotted rotors. and the problem is the steerning wheel wasn't just shaking, i could hear a very deep braking sound, like a DEEP scraching sound.....
Old Feb 10, 2005 | 02:46 PM
SoonerFan's Avatar
Cletus
bad pads...
Old Feb 11, 2005 | 05:43 AM
ddh1313's Avatar
yeah...never ever replace rotors without replacing pads. You were doomed from day 1.
Old Feb 11, 2005 | 07:40 AM
mdloops's Avatar
Dare we ask what you consider high speed braking? Does that include slaming on the brakes at 110MPH? What speeds are we talking about here?
Old Feb 11, 2005 | 08:10 AM
kcowden's Avatar
It's the rotors again... same problem here. On my second set and working on my third. Glad I'm still under warrenty. Crappy OEM rotors. I'll probably get one more set before I'm out of warrenty then I'll get aftermarket ones.
Old Feb 11, 2005 | 08:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If you replaced the rotors vs. turning them, you over torqued the lug nuts, which caused the rotors to warp FAST.
Use a torque wrench next time.
Old Feb 12, 2005 | 05:33 AM
skyjay617's Avatar
like from 80mph to 60mph....it's shaking really bad....just like the problem when you have warped rotors
now i know, i should re-tighten them with torque wrench
skyjay617's Avatar
appx how many Lbs??
Old Feb 12, 2005 | 10:05 AM
crispykid717's Avatar
Bigger than Jesus
For lug nuts 72-87 ft-lbs
Old Feb 12, 2005 | 10:15 AM
upstatemax's Avatar
the dealer replaced my front rotors without replacing the pads before (eventhough i asked them to replace the pads) and after 3 months the rotors were warped again... this is when i found out they never replaced the pads... they put new rotors AND pads on for free after that
Old Feb 12, 2005 | 11:54 AM
Ammi's Avatar
350 Detroit Muscle
I always do 80lbs
Old Feb 14, 2005 | 01:50 PM
BLUEMAX01SE's Avatar
stock rotors on the 5th gen max suck in general - your rotors are warped again - i've warped my rotors about 3 times in one yr- my cuz who is a mechanic resurfaced the rotors those 3 times - changed pads just to be sure and the same thing keeps happening - this spring im either gettin slotted or cross drilled rotors so they dont overheat like the stock rotors do - good luck
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
