Crossmember spacers
Old Feb 10, 2005 | 04:21 PM
mdloops's Avatar
Crossmember spacers
Does anybody know where I can buy crossmember spacers? I am looking to put them on the bar just under the midpipe to give a little more clearance. Also any thoughts on whether this is a safe modification to do? I do not want to compromise the structural integrity of the car. I have searched and searched with not much luck.
Thanks,
Mark
Old Feb 10, 2005 | 05:27 PM
ChromeSE5's Avatar
can you use washers?
Old Feb 10, 2005 | 05:56 PM
mdloops's Avatar
I thought of that, but I don't think that would be the safest route to go. I think a machined spacer would be the best route.
Old Feb 11, 2005 | 09:38 PM
young1976's Avatar
I used 10 washers per bolt ( I think 1" diameter and 1-2 mm thick), and got longer bolts too. So that's 80 total washers to space the frame brace down. No problems. I just took the stock bolt and went to Lowe's and found one with the same thread but longer. Unfortunately the washers have some rust on them now. They are not the plated ones I guess. But they work fine.
Old Feb 12, 2005 | 01:52 AM
mdloops's Avatar
There has to be consequences for doing this besides possibly scraping the ground. What role does the crossmember play in the structural integrity of the car? Where is GALO at ??
Old Feb 12, 2005 | 05:41 AM
young1976's Avatar
Mine doesn't scrape because my car is not lowered. I think the brace just ties the right and left side of the car in the middle. The 4th gens doesn't have that brace I think.
Old Feb 14, 2005 | 04:57 AM
juniper9803's Avatar
I Used Rubber Speacers. They Worked Fine
Old Feb 14, 2005 | 05:45 AM
young1976's Avatar
A solid machined spacer or 10 washers, what's the difference? It's not like the 10 large washers are going to compress like rubber spacers (Below).
You won't find a washer that's 1 in thick. I haven't seen them. Especially a machined one. It would have to be custom made.
I wouldn't use rubber because it'll flex. The whole point of the brace is so there's no flex. That's why I used large diameter washers to balance any twisting load that'll be on the bolts. The washers stick out past the edges of where the holes are on the brace.
Old Feb 14, 2005 | 02:37 PM
mdloops's Avatar
You make a convincing point.
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
