weird noise
Old Feb 10, 2005 | 04:30 PM
nytrida's Avatar
weird noise
when im driving between 2250-2750 RPMs in second, third or fourth gear i hear a ridiculous rattling noise. I'm not exactly sure where it's coming from. My best guess is the transmission since it's only when i hit the gas lightly. Not at open throttle. It's a six speed with 62000 miles on it. Changed the tranny fluid first time at 25k, second time at 47k. Any suggestions?
Old Feb 10, 2005 | 06:36 PM
kratz74's Avatar
Just a guess...but check your exhaust and see if it has shifted on the rubber hangers. Sometimes it will just slightly ban underneath and sound like you describe. get under the car, grab the exhaust in a few places and shake. If it hits-likely its your problem
Old Feb 10, 2005 | 06:47 PM
nytrida's Avatar
I never thought of that. I do have a Greddy Evo so it's possible that could be the problem. I shall check it out tomorrow. If anyone else has any other suggestions i'd grately appreciate it and i'll post what i find with the exhaust tomorrow.
Old Feb 11, 2005 | 07:08 PM
nytrida's Avatar
anyone else have any ideas? Doesn't seem to be an exhaust problem...
Old Feb 12, 2005 | 03:10 PM
jkayca's Avatar
Try tightening the cat heat shield.
Old Feb 21, 2005 | 09:44 PM
nytrida's Avatar
tried both of your suggestions...neither of them seems to be the problem. It seems something is rattling inside the engine as it is turning if that helps for description. Please, if anyone can be of further assistance I'd grately appreciate it.
Old Feb 21, 2005 | 10:03 PM
3x10^8's Avatar
Although I drive an automatic, I experience something similar. At a little under 1500 RPM, when I press on the accelerator lightly, there is a vibration coming from the engine. It's a very high frequency vibration. I'm gonna have my valve brackets checked out to make sure there isn't any contact. BTW, is there a TSB on the valve brackets? Just curious. I wouldn't even know where to check.
Old Feb 22, 2005 | 09:05 AM
00Max00's Avatar
This topic have been discussed plenty of times. The rattling noise is your engine pinging, still has not a feasible solution. One of my guess is engine running too lean, the pinging usually happens under light throttle input and the car is fully warmed up. Maybe needs a tune up.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
