Question about the heater.
Not that I know of... in fact, some times people run their heaters when racing the quarter mile comps... This way they keep the engine some what cooler, and it keeps your quarter mile times close (so you don't break out, or underperform.) The air conditioner takes up horses and gas milage because of running the condencer.
Not to hijack this thread, is there a way to get the auto climate control system in the gle just to have air from the outside pass through the vents? With my 93 maxima all I had to do was make sure the air recycler was off and the switch was in the right psotion and and just let the air come in. Is this possible with the newer systems.
what i meant is whith the AC off and not blowing, can you get fresh air into the car through the upper vents simply by opening the vents and having the circulation off. This was a feature in most cars a few years back.
You still highjacked it. Anyways, back to the original question. Any one else have information?
By using your heater you are making your engine more efficient. The heat created from the internal combustion is being used to heat your car. Plus your helping remove heat from the engine making it more efficient. In the summer time it is wasted energy. With the heater on the engine has to naturally turn the waterpump to move the coolant and power a fan if you turn it on. With the AC the engine also has to turn the compressor and power the various equipment for the AC.
Originally Posted by DAP
By using your heater you are making your engine more efficient. The heat created from the internal combustion is being used to heat your car. Plus your helping remove heat from the engine making it more efficient. In the summer time it is wasted energy. With the heater on the engine doesn't has to naturally turn the waterpump to move the coolant and power a fan if you turn it on. With the AC the engine also has to turn the compressor and power the various equipment for the AC.
Thats what I was thinking, too. Thanks.
Anyone else have information on this???
Unclejunebug
Apr 2, 2016 05:42 AM
