reverse light project
Old Feb 11, 2005 | 06:56 AM
ckohl23's Avatar
hey everybody... crazy question here but would it be possible to wire up some old headlight bulbs i have to my reverse lights? i'm trying to make them brighter for better visibility when i back up in my car. the ones i'll probably use are the same size as the max hi beams. i'm pretty handy with wiring and stuff, but i'm wondering if you think it would cause any problems. i guess i might blow a fuse but what else could go wrong? i don't want to cause any permanent damage if possible. comments and suggestions appreciated! thanks..
Old Feb 11, 2005 | 08:21 AM
MacAlert's Avatar
Hey, hows the VB mod doing?
Old Feb 11, 2005 | 08:41 AM
BLUEMAX01SE's Avatar
headlight bulbs used as reverse lights? man how much light do you need to see to back up? i mean do you drive in reverse for more than 1 block? - i would just recommend using hyper white revrerse bulbs ans that should be plenty of light- forget rewiring everything to get a headlight bulb back there , then you may have problems with the fuses, not only that you have to get the connector to fit back there to hold the bulb in place - imo not worth it, find some hyperwhite reverse bulbs - cheap mod and worth it too, prbly like $10 bux max!
Old Feb 11, 2005 | 08:45 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes, you can use an old H-3 Bulb. You have to carefully strip away the plastic housing so that the contact points and bulbs remain, the fit it in. I know this sounds like a rather vauge description...which it is! There is a member whom did this that posted about within the past 24 hours. I read it around 5am, so...I know it's on here somwhere!!!!
So in summation, yes...it can be done with an H3, but I can't give you specifics.
Max_N_Action's Avatar
people have put h3 fog lights bulbs there....its somewhere on the org i just dont know where...
Old Feb 11, 2005 | 09:16 AM
NYPD-Arnold's Avatar
Z
It was done recently. I know my boy PoLo did it. I saw pics, and the sh*t looked awesome!
Old Feb 11, 2005 | 09:26 AM
nismax96's Avatar
I was thinking of ordering hyper whites from Custommaxima. Can someone tell me what size to get for the reverse lights?
Old Feb 11, 2005 | 05:09 PM
bladerunr's Avatar
I did the H3 backup bulb mod last week. You can't get any brighter than an H3 bulb. Looks awesome! The bulb doesn't fit exactly but it sits in the housing good enough to light every time I throw it in reverse. You must carefully take apart the H3 bulb to expose the 2 leads. You also have to use a pair of needle nose pliers and chip away some of the glass bulb around the leads. I then took each lead wire and bent a little hook into them with the pliers. That will make sure the bulb stays in the housing. Make sure to wipe the bulb clean before lighting.
Old Feb 11, 2005 | 09:01 PM
ckohl23's Avatar
sweet! i never considered using the H3 bulbs instead of my old hi-beams. duh! i have a spare set of those too since i upgraded the bulbs to silverstars. i'll try it out, hopefully i can deconstruct the leads part of the bulb good enough. thanks!
p.s. hi macalert ...the VB is doing great. never had a problem, it's a great mod for autos.
Old Feb 11, 2005 | 10:24 PM
young1976's Avatar
if you go to home depot or lowes, go to the light bulb section and look for quartz/halogen T4 (I think) 50w 12v bulbs. Looks just like h3 without the metal cage. and only around less than $5.http://forums.maxima.org/showthread.php?t=370469
Old Feb 12, 2005 | 08:41 AM
Audtatious's Avatar
Bandwagon Lover
http://www.moodym.com/maxima/tech/maxbulbchart.html
Old Feb 12, 2005 | 02:17 PM
Redstone's Avatar
Anyone ever tried a rear fog light mod using a led of the same wattage as the brake lights. I am about to try this mod but in the end I will only have one reverse light and the other light will be a rear foglight which will be used in FOG ONLY or heay snow especially with drifting conditions to avoid a rear collision for the stupid people who follow too close even when the can hardly see.
Old Feb 12, 2005 | 02:19 PM
FriscoMaxima's Avatar
lol, you might as well pit H3 HID kit in your reverse lights while you are at it.
Old Feb 12, 2005 | 05:30 PM
idonkare's Avatar
How bright you lookin to go? I just put in some Polarg M-6's for backups and its totally brighter then the stock bulbs (though the clear housing has that blue shadow effect during the day)
Old Feb 12, 2005 | 05:43 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
HID for the reverse light.......... ok..............
Old Feb 14, 2005 | 03:33 PM
ckohl23's Avatar
i have the polarg m6's already. they're ok, but i was expecting better, and i'm not into the blue look. i've had them for a while though and i'd agree that they are better than stock. but i'm looking to step up... thx
Old Feb 14, 2005 | 03:36 PM
KCMC582's Avatar
its kinda hard to see, but here is a reverse light HID on a 5th gen accord wagon
http://www.imagestation.com/picture/...f.jpg.orig.jpg
MAXSE5SPD
Sep 17, 2022 04:00 AM
fastcarny
Oct 6, 2015 10:42 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
