Stillen front lip doesn't fit 100%
Old Feb 11, 2005 | 07:29 AM
ZeRo MaX's Avatar
So I got a Stillen lip from SWA... and decided I should test fit it.... it's not a BIG problem but I'm not sure what I can do next to adjust the fitment... well anyways... the lip seems to fit fine from the sides but in the front... the slits do not match up evenly so the middle won't go in all the way. 2 of the slits I can put thru but the other 2 is uneven and are a couple of centimeteres away. I'm not sure if I should just cut the slit to be bigger so it can be fitted in 100% or if there is something else I can do! Thanks for the help!
Old Feb 11, 2005 | 07:41 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Hey, Zero - post some pics when this is done...I want to see what a 5th genner looks like with the lip!
Old Feb 11, 2005 | 08:06 AM
scopium
i had the same problem..i think everyone does..
the lip looses its form a bit during shipment.
i just took a razor and trimed off a bit of the slits little at a time..
Old Feb 11, 2005 | 09:12 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
check my webpage...
I had the same problem in one of the sides.. the sucker doesn't wants to go in.... have no idea on how to make it work. I'll be sending mine for painting soon.
Question:
I'm planning to use the bolts that came with the Lip, do I have to make the holes and fit it before paiting or not?
Old Feb 11, 2005 | 09:23 AM
scopium
well its good to do a test fit.. but not necessary...i just slapped mine on after i got it painted... just make sure you lay a blanket or something soft under the bumper so if it falls in the process you dont scratch the paint
oh and make your your test holes are smaller than your actuall holes..
Old Feb 11, 2005 | 09:38 AM
ZeRo MaX's Avatar
I guess i'm just gonna trim it with a razor :-x
Old Feb 11, 2005 | 03:08 PM
$tillenmax2k
It must be fitted and drilled before painting.
Old Feb 11, 2005 | 03:40 PM
Ammi's Avatar
350 Detroit Muscle
Weird. Mine fit fine.
I lined up the slits first and by the time I got to the fender area lip was really tight, which that's how I wanted it.
Old Feb 11, 2005 | 04:51 PM
ZeRo MaX's Avatar
I tried to line it up by the slits first also.. but after 2 was in.. i realize the other side wasn't even in... so now.. i'm not sure if time will let it expand :-x... or if it would just fit somehow.. but if not.. i will use the razor method...
Old Feb 11, 2005 | 05:09 PM
maximusprimus's Avatar
u know what sucks, is that u cant remove the foglight with lip on. so what ever u do put in whateva fog lights u like first.
Old Feb 11, 2005 | 07:22 PM
Ammi's Avatar
350 Detroit Muscle
You don't have to remove it completely. Just pulled the sides far enough to remove the fogs. It sucks though either way.
Old Feb 11, 2005 | 08:21 PM
Kruppa's Avatar
so you can still change the fog light bulbs with the lip on tho right...just more difficult? cuz i'd assume you can do it under the car behind it instead of pulling it out through the hole in front of the car
Old Feb 11, 2005 | 08:23 PM
Kruppa's Avatar
from what i've seen in person and from pics online it looks like the foglight can still pop out ...there's a little bit of space for it to fit if the lip is flush and on correctly i think altho i don't have mine on yet so i don't know for sure of course
Old Feb 11, 2005 | 08:36 PM
Ammi's Avatar
350 Detroit Muscle
You can change the bulbs w/out removing the foglight housing. I needed to remove mine to install HIDs.
Old Feb 24, 2005 | 03:36 PM
TDotMax's Avatar
ANyone have a pic of this problem? The lip I bought (seller said is MAxxtunning, but I'm having a fittiment issue so it may be the stillen actually) is having a prob going on...The guy is saying its to small. I'm not sure exactly where. I want ot go into the shop tomorrow to find out whats not fitting..Does anyone have a pic of exactly what does not fit? I just need to know as my car will be complete monday, and I need to let them know for sure by tomorrow evening. So if someone can let me know...Thanks a lot.
tcb_02_max
Sep 23, 2015 06:18 AM
sonic7
Aug 20, 2015 12:23 PM
MaxStock
Aug 14, 2015 10:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
