Which is the 4th cylinder
Old Feb 12, 2005 | 03:09 PM
Gopx101's Avatar
I posted earlier about problems with my 00 SE and after doing more research I have discovered that I have a P0304 code. The only question that I have is how do I know which is the 4th cylinder?
Do they start from the front left 1-2-3 to the top left 4-5-6?
Old Feb 12, 2005 | 03:43 PM
imported_Max_TL's Avatar
on the 3.5 it's the middle front, don't know for sure yours ....
Old Feb 12, 2005 | 11:23 PM
Trance Artur's Avatar
It goes like this:
1 3 5 Rear
2 4 6 Front
So the 4th cylinder would be the middle front.
Old Feb 13, 2005 | 08:00 AM
SoonerFan's Avatar
Cletus
and this is all shown nicely in a picture in your owners manual
Old Apr 21, 2009 | 08:09 PM
fugiwara's Avatar
HI, I have the same code in my 95, changed coil pack, #4 cyl still miss fire, I am guessing it's the injector, b/c I had miss fire before at cyl 2 and the shop replaced injector and fix the problem, and yes there are oil on my plugs
Old Apr 22, 2009 | 04:59 AM
vball_max's Avatar
Originally Posted by micheljaw
Which would reach the ground first: hollow or solid cylinder?
This is a 4th year student. I need help for Physics.
If a hollow and a solid cylinder were rolled down an inclined plane, which of the two would reach the ground first? Please explain why.
Really??? What the hell does this have to do with the #4 cylinder???
Good luck getting to 15 posts with posts like this.....
However, to answer your question, it depends on if you are neglecting air resistance. If you are neglecting air resistance they would reach the ground at the same time. If taking air resistance into account, the solid one would reach the bottom first.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
