Birds under my hood?
Old Apr 21, 2009 | 01:05 PM
phxgold's Avatar
Spark her up in the AM to warm up and after about 3 minutes I get a chirping from under the hood can find the source anyone had this issue?
Old Apr 21, 2009 | 01:10 PM
Weeble1's Avatar
The Whistle go WOOOOO
could be a few things...Belts, one of the pulleys, water pump...I'm sure there is more.
Old Apr 21, 2009 | 01:11 PM
Blitzfist's Avatar
belts...more then likely accessories/drive
AEMAXIMA01's Avatar
So you can or cannot find the source? Your sentence is somewhat hard to understand as a run-on.
Old Apr 21, 2009 | 01:33 PM
phxgold's Avatar
sorry I can not find the source.
the belts are new the pully is a new unorthadox racing light weight pully.
had belts checked for proper tension that seems fine.
Old Apr 21, 2009 | 01:38 PM
Weeble1's Avatar
my vote is water pump
Old Apr 21, 2009 | 06:35 PM
maximase86's Avatar
I love lamp.
You might also check idler pulley...could be a bearing on it's way out...or one of the accessory pulley.
S
Old Apr 22, 2009 | 05:45 AM
ridinwitha35's Avatar
One of my radiator fans made a squeaky noise...first I thought it was the belts. Then the squeaks went away and was replaced with a rattling sound along with massive vibration. Now I'm only on a single-fan with no overheating issues. Then again, it's not summer time yet so it remains to be seen if I can truly get by on one fan.
Old Apr 22, 2009 | 08:04 AM
o0zarkawater2's Avatar
I had a similar sound a couple years ago, squeal on startup and then occasionally on hard throttle when the a/c was on. I had a mobile mechanic, who was at work working on someone elses car take a look, he said it was probably the a/c clutch.
Found that was expensive to fix, so I looked more into it and it ended up being the idler pulley. Bearings in it were going out. New idler pulley/belt fixed my problem. No squeaking since.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
