Dash Clock Removal
Old Feb 15, 2005 | 11:09 AM
HenryNYC1's Avatar
Dash Clock Removal
I have an idea that the clock just pops out cause it's only held down by clips. Can someone confirm this before I try and yank it out. Need to slap some padding in there. The rattle there is driving me up the wall..
thanks
Old Feb 15, 2005 | 11:15 AM
hct67's Avatar
Yes it does, just pry up on one side and it will pop right out for you
Old Feb 15, 2005 | 11:26 AM
HenryNYC1's Avatar
Cool thanks!
Old Feb 15, 2005 | 12:41 PM
kclmax2k1's Avatar
Be careful when you do it! The matel clip may drap (I lost one)and you won't be able to get it back without completely remove the desh.
Old Feb 15, 2005 | 02:08 PM
HenryNYC1's Avatar
eeeeP! good looking out
Old Feb 15, 2005 | 03:23 PM
nicks79's Avatar
What actually causes rattle there? Cause I got the same damn problem!.
Old Feb 15, 2005 | 07:01 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
talkin about the clock, does anyone know the wire to cut so the clock wont dim? thanks.
Old Feb 15, 2005 | 09:30 PM
HenryNYC1's Avatar
Not too sure what it is but it sounds like either hard plastic snapping each other or lose wiring slapping against plastic. I will update this once I get a chance to take a look at it. probably tomorrow night after work.
Old Feb 16, 2005 | 12:36 PM
jreddington3's Avatar
That wire slapping on the underside of the dash sounds exactly like what I have on my '03 SE. I've brought it into the dealer three times under warrantee about it and they can't track it down. On one try they said a clip on the clock mount was broken and they ordered a new one. But when I picked up the car and looked at the work order that said they replaced the radio surround.
It's not a real bad noise and seems to come and go but with the rest of the car bank-vault solid it sticks out and is very annoying.
If you track it down, please post.
Old Feb 16, 2005 | 07:13 PM
Nomad's Avatar
All right guys i've just took my clock to chenge LED and lost one metal clip. Does anyone have an idea where to get one?
Thanks.
Old Feb 16, 2005 | 09:06 PM
kclmax2k1's Avatar
Welcome to the club. I also lost one. I tried to use some magnet to get it but no luck. I think the only way is to remove the whole desh.
Old Feb 17, 2005 | 05:44 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
Can you vacuum it up? Stick in the hose from a ShopVac, suck it up, and dig it out from the recepticle?
Old Feb 17, 2005 | 10:53 AM
colonjdb's Avatar
Not sure if you can vacuum it up but if you can 1st place a panty hose over the vacuum nosle so that way it will stay trapped there and there will be no need to dig for it.
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
jaydot901
Sep 29, 2015 01:18 PM
salty318
Sep 28, 2015 07:22 PM
