Blown Springs / Alignment Problem
Old Feb 17, 2005 | 01:18 PM
rLx77's Avatar
I've had to get 3 alignments in 6 months since I bought my 2001 I30T. I believe my struts/springs are blown, because I have a terribly harsh ride.
I feel every single little bump in the road, and recently I can also feel the car swaying side to side when I go over "cobblestone" like roads. I just got an alignment a month ago, and last night I drove over some really bad roads a little too fast (maybe going 25 or so), and I think my alignment is crooked again (dang it!!).
I'm getting tired of spending $90 or so on alignments - would replacing my struts/springs first, then getting the alignment be better? I want a soft soft soft ride, and I'm interested in what kind of struts/springs package will I need to achieve that?
I'm thinking with new springs/struts, this will keep my alignment straight for a longer period of time.... what do you guys think?
Old Feb 17, 2005 | 01:26 PM
MaximaPolak's Avatar
Is this the stock suspension? If so you can go to Firestone or somethign like that and get a lifetime alignment for one hundred something dollars.
Old Feb 17, 2005 | 02:28 PM
rLx77's Avatar
hmm interesting.. thanks... yes stock suspension. crappy stock i must admit for touring model.
Old Feb 18, 2005 | 06:11 PM
theMax's Avatar
springs usually don't blow, I bet it is the struts. Push down on each corner of the car if it bounces a few times the struts may be blown.
Old Feb 19, 2005 | 05:33 AM
njmaxseltd's Avatar
Put a set of Tokico Blue performance struts and rear shocks in your I30t. They are a direct OEM replacement and will give you that new car ride back. They ride very smooth. Have your alignment set after the installation. Bumps should not throw off your alignment that fast, you might have something loose in your suspension. Worn out struts are probably whats giving you the harsh ride. Make sure your tire pressure is set correctly, don't use the max. on the tire's side wall, use Infiniti's recommended pressures which should be around 35F / 32R COLD.
Springs don't ware out, you don't need to replace them. The struts are what provide you with ride control and comfort. The I30t comes with a nice suspension setup. Your just needs to be refreshed.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
