Brembo Brake Rotor and Pads
Old Feb 20, 2005 | 01:30 AM
Adi G. Wijaya's Avatar
Hi all,
I would like to change my front brake rotors and pads. I am having brake judder when braking at the speed around 45-85 mi/hr.
What do you guys think about my decission? Is brembo pad good?
I have heard about the good of Axxis brake pad. But since i would like brembo rotor, so why not to have brembo brake pad as well.
Do you guys have any complain by having brembo coss drill and/or slot? Since i read some people said that it is noissy or humming, please clarify.
Thanks a lot.
Old Feb 20, 2005 | 05:20 AM
Melaza's Avatar
As far as i know after a while the cross drill rotors they crack, so i just went with the slotted once, plus i used bendix pads, and i never had a problem....just my opinion.
Old Feb 20, 2005 | 09:19 AM
Does that mean that slot is much better? Does that also mean that slot is better than stock rotor?
Old Feb 20, 2005 | 09:38 AM
makavelisk's Avatar
Nope.....not unless you get a BBK you are not gaining any performance with slotted or cd rotors. They are just for looks.
Old Feb 20, 2005 | 09:39 AM
XGaSpAcHo
from what i understand the x-drilled ones might crack around the holes and are noisier. you don't really need them. any rotor will probably be better than the stock ones and not warp as much or as quickly. also see if you can get ceramic brake pads (i think that's what they're called) that way you wont have as much dust coming off.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
