S-AFC hookup help for '01' AE
I've had this S-AFC collecting dust for awhile and want to hook it up. Does anyone know ECU pinouts for 01' Hopefully with the intake, Y-pipe, and freebie mods alittle fuel curve adjustment will net some more power/fuel efficiency. I know on past cars I've modded they seemed to need leaning out. Also I should be monitoring from the last O2 sensor right? Any help is appreciated.
leaning would probably help because the PCM uses a strategy to control fuel at WOT rather than sensors. The factory settings are probably set rich to protect the engine. use the down stream sensors-they are monitors. The upstream sensors are what control the mixture. hope that helps
Maximus99
May 29, 2002 09:37 PM
