Big brake Kit
Old Feb 28, 2005 | 10:14 AM
  #321
Jeff92se's Avatar
I'm needing a caw
Galo, I need to talk to you anyway so check your pms in a min.
Technically you might be able to affect the bias via pads. Slightly. But I have never seen/heard/read any pad maker suggest that pads might aversly affect the ft/rear bias.
Using multipiston calipers AND using a bigger rotor for a larger torque arm, has A MUCH greater affect on the amount of force applied onto the rotors than a pad ever would.
IMHO. Let's say you used the highest co of friction pad that chews though your front rotors and only works when they are extremely hot. Then used the crappiest rear pads you could find. I doubt that situation (however extreme that might sound) would come close to affecting the frt/rear bias enough to warrant a design change.
Think about it. If you really had that much power with just pads, BBKs would never be offered, car makers would never even offer them and you would see many tests that show a pad only change can make great differences in braking distances.
On that note though. If you are wearing out your rears every 26k, maybe Nissan tried to up the rear bias in an attempt to increase braking performance of the later maximas. But I haven't read to much data to back that much too much. I saw a 2000 maxima 60-00 time of about 126-13x ft. I don't know what a 3-gen does but I'll look it up. I don't "think" it's that much better or worse. But FYI, I have gone over 100k and my rear pads are barely worn. So I definately needed more ooph in the rears after putting on my own bbk.
Old Feb 28, 2005 | 11:03 AM
  #322
Galo's Avatar
Maxima Pilot
Jeff, of course I agree with you...the difference would be slight, definitely the mechanical/physical aspects you describe will have much more effect than pad compound -but intuitively, one could see where pad compound would indeed make a difference by looking at the graphs here. Granted, not a big difference but.....you can see here where one pad's CoF (the T compound) begins to drop at the same time the Q compound's CoF begins a rather marked rise.
http://www.wilwood.com/BrakePads/003-DESC/index.asp
BTW, I originally installed the Q compound pads with my brakes and then switched to the T compound -which actually drops in CoF after 500 degrees- and found my brakes to work better and quieter...maybe that 'better' was that these pads maintained a better front/rear effective bias.
On my rear pads, they were about 60% gone so..I figure they would have lasted about 40k miles. The reason I replaced them was a warped rear rotor -potantially another piece of evidence that my front/rear bias is not too bad...
Another PS edit: if you peruse the Wilwood site, you can see that both the T and Q compound are very easy on rotors, meaning one can find pads with various CoFs that dont necesarily eat rotors up...
Old Feb 28, 2005 | 11:13 AM
  #323
Jeff92se's Avatar
I'm needing a caw
Galo. You need to stop listening to Icy. He's a tard.
Anyway, I think if you can get a pad that needs to be somewhat friendly to rotors, then I think you can only expect so much performance from them. You can get them to perform when cold(which is a necessity) and then give up some when really hot. Or peform well when hot and give up when cold (bad idea) etc...
Do you have a factory fsm? It should list the oem bias in the brake section. I'd be curiuos to know what it is.
Old Feb 28, 2005 | 11:15 AM
  #324
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Galo,
I agree on the rear pads...
These white papers by StopTech really opened my eyes on variables that can be optimized to shoot for factory front/rear bias:
http://www.stoptech.com/whitepapers/...erformance.htm
Also, here is one on just REAR brake upgrades:
http://www.stoptech.com/whitepapers/...tter120601.htm
Old Feb 28, 2005 | 11:23 AM
  #325
Galo's Avatar
Maxima Pilot
Ahh.....I'm not touching that one even with an 11-foot pole....LOL!!!!!!!!
Or perform well when hot and give up when cold (bad idea) etc...
Yes, indeed -very bad for street driving...
nope....dont have one
  #326
IceY2K1's Avatar
I see...
Control Valve
Applied pressure(front) = 1,067psi
Output pressure(rear) = 739-796psi
Old Feb 28, 2005 | 11:29 AM
  #327
Galo's Avatar
Maxima Pilot
Originally Posted by IceY2K1
I see...
[b
Control Valve[/b]
Mnnnn....interesting!! These numbers imply about a 70/30 bias in stock form for a car whose static weight distribution is 63 front 37 rear.....that does not seem to be enough front bias for any reasonably hard stop...
Of course, then all the other mchanical variables come into play and Lord knows what this equates to in terms of actual retardation force.
I give up. Those facts plus reading the Stoptech article about the elusive perfection means the're no way we are gonna get to the bottom of this without a Cray computer....I'm gonna go back to work....that's easier
Old Feb 28, 2005 | 11:33 AM
  #328
Jeff92se's Avatar
I'm needing a caw
hehe. Galo. Cracks me up. 70/30 is about right. And if you remember, Matt93se's long post on brake bias (which Driven clearly ignores) talks about what a bbk changes the frt/rear to. And why he made the the rear bbk. I think the post also mentions a 70/30 split.
Old Feb 28, 2005 | 11:41 AM
  #329
MAX2000JP's Avatar
You bring up a good point. A well designed brake system will take into account the weight distribution of the car.
Old Feb 28, 2005 | 11:48 AM
  #330
IceY2K1's Avatar
IMHO...I'm feeling the 2K4 caliper/rotor setup, grippy tires, lowering the CG of the car, and maybe better pads in the rear is best for those that don't want to upgrade the rears, ie the majority here.
However, for the Z32 front calipers or most of the BBK calipers out there that dramatically increase FRONT rotor/piston size, you MUST run Matts' REAR BBK to end up near factory bias.
Looking at all of this now, I'd rather have gone the 2K4 route and not messed with the PITA rears, however for ~$1K for Matts' REAR kit+Z32 calipers/rotors/pads, it should put me back in the "safe" factory bias range.
Old Feb 28, 2005 | 11:55 AM
  #331
irish44j's Avatar
retired moderator
um....is this using Matt's "formula?"
because if not:
1067 FRONT 60%
739 REAR 40%
or 1067 FRONT 57%
796 REAR 43%
Old Feb 28, 2005 | 12:03 PM
  #332
IceY2K1's Avatar
That's just brake pressure proportioning front/rear and NOT the bias.
Old Feb 28, 2005 | 12:07 PM
  #333
irish44j's Avatar
retired moderator
ight...just making sure....my math skills are a litte rusty and couldn't figure out how to mesh the proportioning with the caliper/rotor size bias....
Old Feb 28, 2005 | 12:13 PM
  #334
dizmax96's Avatar
hey Josh.. i jus mocked up the 6th gen calipers with the stock 17".. they clear the calipers.. byabout 1.5mm.. checked it wit feeler gauges.. for those who feel thats too close for comfort..get spacers.. if not.. itll work.. i torqued the wheels on as well.
Old Feb 28, 2005 | 12:14 PM
  #335
IceY2K1's Avatar
Still working on that irish, but *IF* I get it figured out, I'll let you know.
What I do know is that messing with increasing rear bias is like messing with fire and not something to be taken lightly. Also per StopTech, proportioning valves are NOT an answer to fixing an improper biased setup, so choosing your rear bias increase is crucial.
Old Feb 28, 2005 | 12:45 PM
  #336
Galo's Avatar
Maxima Pilot
Yes.
And, after 330-odd posts, I have a solution for a cheap, low-tech rear bias increasing device. Indeed, its the mother of all rear brake bias increasing devices.
e-brake
Old Feb 28, 2005 | 12:49 PM
  #337
irish44j's Avatar
retired moderator
The 17's on the 02-03 are a bit different from the 00-01 17's...I can tell you that the 6th gen setup did NOT clear my 17's.....needed at least a few mm....they must have changed the back design, since mine would rub on the outside of the hub....
Old Feb 28, 2005 | 01:45 PM
  #338
dizmax96's Avatar
i got pics yall.. here
maybe the 02-03 model wheels are slightly different..
i used those 2 feelr gauges together..it cleared.. about 1.5mm.. i jus put them on..man..feels nice.. more confident braking..
Old Feb 28, 2005 | 01:50 PM
  #339
Jeff92se's Avatar
I'm needing a caw
Damn that IS close. Some OEM applications are extremely close too. Maybe not THAT close hehe.
Old Feb 28, 2005 | 02:11 PM
  #340
IceY2K1's Avatar
Well that sucks...I thought 2K-2K1s would be the same as 2K2-2K3s, since the offset is the same just the center cap is different.
That means I'll need AT LEAST a 5mm spacer, since supposedly 2K2-2K3 only needed a 3mm spacer.
Old Feb 28, 2005 | 02:21 PM
  #341
irish44j's Avatar
retired moderator
I was gonna do that...but I just sold my SE rims instead and will buy (for about the same price) some G35 SEDAN 17's, which have a 30-35mm offset and will clear without spacers.....
Old Feb 28, 2005 | 02:22 PM
  #342
dizmax96's Avatar
yeah.. 3-5mm spacers should work..
Old Feb 28, 2005 | 02:30 PM
  #343
Galo's Avatar
Maxima Pilot
Ohh Noble Fishy One: I too have about 1.5 mms between my SSRs and the Wilwood caliper.....it was scary for the first coupla weeks, now it's like, who cares? Not a problem yet....
knock on wood now...
Old Feb 28, 2005 | 02:32 PM
  #344
irish44j's Avatar
retired moderator
boo-ya! damn I wish it would stop snowing!
Old Feb 28, 2005 | 02:34 PM
  #345
dizmax96's Avatar
ahh yes.. the guiness.. haha nice.. front end feels heavy.. i dono if its jus me or wat..
sorrie.. had to post these..
Old Feb 28, 2005 | 02:37 PM
  #346
Jeff92se's Avatar
I'm needing a caw
Well, what the hell!
http://www.digitalbeta.net/jeff92se/photos/IMG_5495.jpg
Old Feb 28, 2005 | 02:39 PM
  #347
IceY2K1's Avatar
ONLY thing too worry about being that close is when you press on the brakes, the caliper could flex/twist and contact/rub, maybe?
Old Feb 28, 2005 | 02:40 PM
  #348
irish44j's Avatar
retired moderator
Yeah, you can definitely feel the extra weight of the rotors. combine those with my G35 rims and I'd probably run 16's in the 1/4 (if I ever wanted to run the 1/4, that is...)
Old Feb 28, 2005 | 02:44 PM
  #349
IceY2K1's Avatar
I was thinking of doing the same, ie cheap 42mm offset wheels BEFORE you guys posted this, but it's too close to call/PITA because the spokes could still be a problem.
Old Feb 28, 2005 | 02:54 PM
  #350
Jeff92se's Avatar
I'm needing a caw
Muhaha. I have clearance for days mang. See the pic. Mega clearance. No spacers. But I do run a hubcentric ring.
Old Feb 28, 2005 | 02:58 PM
  #351
irish44j's Avatar
retired moderator
I know it's so cliche' to say, but......
"Holy Wheel Gap Batman!"
sorry, couldn't resist. Especially since I'm jealous that your 6th gen brakes are on before mine (you must have a garage, because your weather looks like ours...)
on a side note....for your safety's sake, I really hope you're not planning on driving in the snow/slush with those RE92's....
Old Feb 28, 2005 | 03:00 PM
  #352
Jeff92se's Avatar
I'm needing a caw
Maybe he's not a WUSS! hehe. Or has a wife that yells out for the neighbors to hear "WTF are you doing out there! You are COMPLETELY nuts?!"
Old Feb 28, 2005 | 03:02 PM
  #353
irish44j's Avatar
retired moderator
Hey....I like to DRIVE in the snow, not work on the car in it!
Old Feb 28, 2005 | 05:20 PM
  #354
dizmax96's Avatar
i did mine at work today.. wasnt anything to do.. so i pulled it in the shop.. boss left at like noon.. so i had a good 5 hours or so to mess wit it.. hehe. if it was nicer outside.. i woulda busted out my compressor.. need to use that thing..
Old Feb 28, 2005 | 05:49 PM
  #355
IceY2K1's Avatar
I just used my digital "bathroom" 1/2lb increment scale and I got...
15.0lbs +/-0.5 for the Stillen OEM stock size replacement rotor.
and
22.0lbs +/-0.5 for the 13" Stillen BBK single piece rotor.
*CRUDELY* borrowing from the old 8:1, 1-lb of unsprung weight is equivalent to 8-lbs of sprung weight FOR WHEELS/TIRES(not brakes!!), and rounding to 22lbs. means that Jons' BBK or Stillens' 13" 1-piece BBK would be approximately equivalent to ADDing 112lbs. to the cars' curb weight. So, the increased front bias/braking force outweighed the increased moment of inertia created by the larger rotors AND decreased rear brake force.
I'd really like to see what Matts' rear BBK will do on Jons' car.
IceY 04/05 rotor : 21lbs 7.5oz
piston diameter in: 47.5mm
out: 56.5mm
12.6 inch is pretty big compared to the TL's 12.2
Old Feb 28, 2005 | 05:58 PM
  #356
irish44j's Avatar
retired moderator
and
interesting....although this doesn't necessarily account for the extra rotational mass of the larger rotor (similar to a larger rim), which would have a (minor) adverse affect on braking because of increased wheel/rotor momentum.....or does it?
Old Feb 28, 2005 | 06:00 PM
  #357
Driven EF9's Avatar
ding ding.
most OEM calipers are sturdy enough to prevent flex.
however, Wilwood's billet calipers aren't. they are prone to flex...
Old Feb 28, 2005 | 06:02 PM
  #358
IceY2K1's Avatar
That's EXACTLY what it's accounting for, however the 8:1 ratio "rule of thumb" is typically used for wheel/tire(longer moment arm) so it's probably less then 8:1.
Old Feb 28, 2005 | 06:04 PM
  #359
LA02MAX's Avatar
sorry for the newb question, but what exactly do spacers do?
  #360
irish44j's Avatar
retired moderator
That's EXACTLY what it's accounting for, however the 8:1 ratio "rule of thumb" is typically used for wheel/tire(longer moment arm) so it's not exact.
of course it is....I am outthinking myself apparently.....
