00 Stillen Classic Lip Fitment
Old Feb 24, 2005 | 02:06 PM
Kruppa's Avatar
The post a while back about fitment issues...i think i know what the problem is because i had a problem with mine when i went to go fit it on...whichever side you start to put on first...it rests perfectly snug along the lines of the bottom of the car and in the foglight area but those four or five little connectors in the lower valence are what creates the problem...whichever side i start with, the first two fit and then even with force the next couple ones won't slide in bc its a couple of mm off...i suppose easy thing is to just cut them a little larger but i have a feeling that if you heat it up it will be easier to force it a bit and it might just fit like that...anybody else have this same problem and what did you do? kinda ridiculous it's even that much off for how much they charge for it.
Old Feb 24, 2005 | 02:16 PM
Kruppa's Avatar
Nevermind, my bad I found it and it's the exact same problem
http://forums.maxima.org/showthread.php?t=378565
I'll heat the bastard up and see what happens...if not no biggie just use the razor method
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Garrettz459
Sep 28, 2015 02:50 PM
