TSW 18" X 8" Rims for $129.00 !!!
TSW is selling Mak Sonic (7-spoke) 18" by 8" rims on special for $129.00 each. I'm thinking about getting a set and mounting 245/40/18 Kuhmo Ecstas on them. Tirerack sells the Kuhmos for $125.00 each.
Whatcha think?
Whatcha think?
Originally posted by Y2KevSE
Make sure they're not too heavy... otherwise, go for it!
damn .. those r cheap!!!!
Whatcha think?
Whatcha think?
nothing fancy .. but for $129 .. that's pretty good! would u post what they weigh?
btw .. what do our stock 17 x 7's weigh?
IMO, stay somewhere close to 25 lbs.
I'm also curious to know how heavy our stock rims are. Has anyone ever weighed them?
The wheels weigh 28.75 lbs each. Is that too heavy?
Thanks for the feedback. I think I'll hold off for the time being. I'm not in a big hurry to make a decision and they have 60 of the 18" X 8" rims in stock!
BTW, Dave Burnette at Southpoint Nissan has a set of used SE 17" Rims for $900.00. Give him a call at (888)254-6060 if you're interested.
Originally posted by 2Maxed-out4u
will getting 17 pound 18 inch tires give you an increase in acceleration? Or what?
Originally posted by UMD_MaxSE
The amount of torque that is needed for a car to accelerate is dependent on the size and weight of the rim. Basically, it comes down to the rotational inertia of the wheel + tire combination. If we assume that the wheel is simply a ring with all the mass on the edge, the rotational inertia is I = mr^2. If the mass or radius goes up, so does the rotational inertia. The equation for torque is tau = I * alpha. If I increases, then tau(torque) must increase to reach a given angular acceleration (alpha). So the smaller and lighter the rim, the better. That is why 15" steel rims are better for drag racing than heavy 18" alloys.
I also worked the formula in reverse. The 18" TSW rims I was considering weigh 28.75 pounds. If I wanted to maintain the same rotational inertia with my stock 17" rims, how much would they have to weight. The answer came back 32.5 pounds. I haven't weighed my rims, but I suspect they weigh less than 32.5 pounds. So if I upsized to the TSW's, I'd probably be increasing my rotational inertia substantially.
Cool.....nice work. However, the equation I had for rotational inertia, m*r^2 is a bit too simplistic. It assumes that all the weight is at the edge of the rim. In actuality, the wheel is more like a cylinder that has a weight distribution inside also (the spokes). So, to get a real measure, you would have to do a lot of measurements and do some integral calculus to get the true inertia. But, just for comparison purposes, it should give you a nice relative measure. As the more mass is located closer to the axis of rotation (the axle) the inertia will go down. By making the assumption we are, this gives us a bit of a worst case where all the mss is at the edge.
The extra rim weight aint gonna really matter on a MAX that aint trying to get .05 sec off the clock on a 0-1/4mile run.
Just what I know from hardcore racing, back in the days 2yrs ago
Dixit
Interesting formula for rotational inertia...
Next step--a set of 20" (40 lb) wheels. It will take 3.34 hp to wind 'em up to the same speed.
Bottom line: an upgrade from 16" 25 lb rims to 20" 40 lb rims will "tax" your engine about 2 hp during hard 0-60 acceleration. Will it matter? I didn't try to check that out yet
--just my 2 cents
Originally posted by Kostya
Well, I decided to calculate how much power will it take to wind up a set of 16" (25 lb) wheels to 60 mph in 6.7 sec. It appears to be 1.34 hp.
....I wonder if our guys bought either set?
I did the math just out of curiosity. Let me know if you need the Excell file I set up.
0m3nc0w
09-11-2015 05:21 PM
