rear dash removal
Old Feb 28, 2005 | 01:42 PM
OutMaxxed's Avatar
rear dash removal
Does anyone have a write up on how to remove the rear dash? I gave it a look and found behind the rear seat, the pins that hold down the black trim. How do i open those? They look like staple, do i just pull em out? It doesnt seem like a clip. Help is greatly appreciated. Thanks
Old Feb 28, 2005 | 02:28 PM
2K3MAX2NV's Avatar
"tse-tse fly"
Im in the process of doing the same check housecor's site its explains alot
Old Feb 28, 2005 | 02:38 PM
BRINKLEY's Avatar
http://www.innerbean.com/housecor/bose_deck_fix.html
just scroll down, I'm fixing to get into it to as soon as it warms up outside.
Old Feb 28, 2005 | 02:40 PM
ZIPPIN's Avatar
Mauja He Mauja
best thing i did for the bass was to sound deaden the rear dash
Old Feb 28, 2005 | 03:42 PM
drumexpert's Avatar
After extensive research on the forum I came across housecor's site and followed his instructions on how to silence the rear deck rattle. After the tidious process was over, the aftermath was worth the hard work.
Old Feb 28, 2005 | 04:10 PM
Ammi's Avatar
350 Detroit Muscle
I spent all day sunday applying sound deadner my entire trunk, rear deck and the trunk lid. Finally, no more rattling. Cut down on exhaust noise too
Old Feb 28, 2005 | 04:48 PM
2K3MAX2NV's Avatar
"tse-tse fly"
whats the difference between sound deadener and dynamat? where can I get it?
Old Feb 28, 2005 | 04:54 PM
Ammi's Avatar
350 Detroit Muscle
pretty much the same thing. Dynamat is just well known mame. I bought r-blox 50sq ft for $70
Old Feb 28, 2005 | 05:41 PM
ZIPPIN's Avatar
Mauja He Mauja
i used peel and seal from lowes. used a heat gun, and it worked great. i actually tried the peel and seal on the metal shovel i have. after shoveling the entire season, the peel and seal is still on the shovel. i recommend it.
Old Feb 28, 2005 | 05:45 PM
LA02MAX's Avatar
i used peel and seal from lowes. used a heat gun, and it worked great. i actually tired the peel and seal on the metal shovel i have. after shoveling the entire season, the peel and seal is still on the shovel. i recommend it.
great idea! how much did that run you? (price and amount)
Old Feb 28, 2005 | 05:51 PM
ZIPPIN's Avatar
Mauja He Mauja
i cant remember exactly, but i think the roll is 19 bucks. you can do the entire rear deck and part of trunk. i highly recommend the heat gun, about 20 bucks from home depot. i put on some gloves and rolled with my fingers. put some muscle into rolling, and it will not come off,,,,ever!!
Old Feb 28, 2005 | 05:52 PM
LA02MAX's Avatar
cool, thanks a lot..i already have a heat gun, so thats covered, and 19 bucks doesnt sound bad for the amount you said...i definitely wanna get rid of the bose deck rattle before i leave home for 2 months this summer...
Old Feb 28, 2005 | 08:43 PM
tisucka's Avatar
will this remove the rattle in the rear deck from subs also??
Old Feb 28, 2005 | 11:01 PM
ChromeSE5's Avatar
Peel and seal is awesome. The draw back is that it comes in long strips... but that is also a positive because its easier to handle, I lined my spare tire well with it and used dynamat extreme where it was visible (asthetic).
Old Feb 28, 2005 | 11:47 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Most likely (for a while anyways).
Old Mar 1, 2005 | 09:07 AM
OutMaxxed's Avatar
thanks for the site, but he tells us to " Remove 2 side seat pieces by removing bolt at bottom and lifting up". Do i just pop those out? They look like they are stapled in. They dont even seem like screws. What do i do?
Old Mar 1, 2005 | 11:27 AM
bigsherv's Avatar
Man the peopel at Lowe's do not know what peel and seal is. What does the packaging look like. Anyone from Houston purchase this at Lowes? If so which one?
Also which version do you use?
http://www.mfmbp.com/Spec.htm
Old Mar 1, 2005 | 11:52 AM
bigsherv's Avatar
I just read in an audi forum that peel and seal stinks when the car is kept in the heat. Is that true?
Old Mar 1, 2005 | 09:39 PM
bigsherv's Avatar
so I guess no one has any smells from the peel and seal? Anyone in a warmer cliamte, TX, AZ, CA, use it?
Old Mar 2, 2005 | 03:52 AM
ZIPPIN's Avatar
Mauja He Mauja
i have had it for 2 years and it does not smell
Old Mar 2, 2005 | 04:17 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I recommend eDead for sound deadener. It's 45mils thick for a meagers $1/sqft. The stuff applies VERY easily and is bar none the best stuff out there, IMHO. Dynamat works OK, but is waaaaaaaaay overpriced.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
jholley
Aug 30, 2015 06:39 AM
