View Poll Results: What do you think of the smoked side markers?
Love them
79
41.36%
Like them
56
29.32%
They're OK
48
25.13%
Hate them
4.19%
Voters: 191. You may not vote on this poll
Smoked side markers
#241
Originally Posted by Deckdout2
believe it or not, no i haven't. that will be done tomorrow. just had to wait to have some time and dry weather to occur together. i'll post new pics once the clearcoat has been done.
o i haven't forgotten about emailing you those pics of the clears either, my schedule here at work has just been all wacked, and afterwork my girlfriend always has something for me to do. i promise i'll get to that tomorrow also. sorry bout that.
i should be meeting up with the guy who has the other set of clears tomorrow so whenever you get around to it just send me the pics. let me know if you need my email address.
#242
#245
heres what some of you have been waiting for... smoked markers on a sterling. heres my webshots.
http://community.webshots.com/user/xstraktorx
#246
#250
Originally Posted by fishpony
Ya i need a set for my 03'
#253
I don' think smoked corners look good on lighter maxes. I feel that when you do something like that, the colors chould "compliment" eachother. Like the clear tails on sterling mist and white maxes and black tail lights on black and midnight blue maxes. You shouldn't clash the colors
#255
#263
Update on Rear Smoked SM
Spoke with Jose at CE, Greg is out sick with some type of summer flu. Jose, said they are not in yet and for me to call back tomorrow when Greg is in to get a time frame.
#265
Originally Posted by XGaSpAcHo
those don't really looked smoked at all. just very slight. what did you use?
#267
Any chance you got an update from Greg? Thanks for the help man.
#269
Haven't gotten an update yet as far as eta. Some other guy that I spoke to said that they weren't in yet. Greg has a more definate date, but he hasn't responded yet. I'll try to get ahold of him again.
#273
Originally Posted by MaxSE-R
will there be a GD when the rear smoke lens come out?
#276
Originally Posted by 03MaXiMa_RiDa
hey for the m4 polar bulb how bright is that blub? and would it be legal if i had my corners white??
#277
Keep in mind this is for NC only. Some inspection "Know It All" said I wouldn't pass inspection because my lights emitted a white light and not orange. I told him to bring his manual out, then I told him to go and take the certification class again, when I pointed this out. The rule of thumb is your bulb cannot be blue or any color other than clear or orange. That's what they make chrome bulbs for.
19A NCAC 03D .0533 LIGHTS
1. Headlights shall not be approved if:
(a) There are not at least two head lamps (at least four on dual
head lamp systems which require four units) on all
self-propelled vehicles except motorcycles and motor driven
cycles need only one.
(b) The lens produces other than a white or yellow light.
(c) Any lens is cracked, broken, discolored, missing, or rotated away
from the proper position, or any reflector is not clean and bright.
(d) The high beam low beam dimmer switch does not operate properly
or the high beam indicator light does not burn on vehicles
manufactured after January 1, 1956.
(e) Lights can be moved easily by hand, due to a broken fender or loose
support, or if the mounting does not make a good ground.
(f) Foreign materials (such as shields, half of lens painted, brush
guards, etc.) are placed on the head lamp lens that interferes with
light beam of lamp.
(g) Lights are improperly aimed using an approved light-testing device.
(h) Lights project a dazzling or glaring light when on low beam.
(i) Mechanical/wall chart aimer tolerance range is 4 inches up, down,
left, and right. On board aimers tolerance is .8 up, down, left and
right. Optical aimers are either go or no go.
2. Rear Lights shall conform to the requirements of G.S. 20-129(d).
Taillights shall not be approved if:
(a) All original equipped rear lamps or the equivalent are not in
working order.
(b) The lens is cracked, discolored, or of a color other than red.
(c) They do not operate properly or do not project white light on the
license plate.
(d) They are not securely mounted.
(e) The lens is clear and the bulb is colored.
(f) The lens is covered, smoke tinted, lettering or logos, etc.
3. Stoplights shall conform to the requirements of G.S. 20-129(g).
Stoplight shall not be approved if:
(a) The lens is cracked, discolored or of a color other than red or
amber.
(b) It does not come on when pressure is applied to foot brake.
(c) It is not securely mounted so as to project a light to the rear.
[Includes third brake light if vehicle is so equipped]
light beam of lamp.
working order.
license plate.
amber.
