Brake Lights Out... Got pulled over?
I got pulled over today because my two brake lights were out. I had no idea... My tail lights do light up when my lights are on but my back two brake lights do not light up when I hit the brake. My spoiler light comes on when I hit the brake though. I check my fuses and they are good. What could the problem be? Anyone else have this happen before?
I have had the problem with one of the bulbs. Since the bulb is a dual filament bulb, the light would turn on when the brakes would be applied but not with the headlights (running lights). It was that the bulb had come loose in the harness. You really have to snap it in there. I know what I described is the exact opposite of your problem, but it should be similar. Otherwise, replace both bulbs for $5. If you got a ticket, it was probably a fix it ticket and you just need to prove it's been fixed. Good luck.
no, I didn't get a ticket... he just said, "ok as long as you are aware of it" and let me go. The cops around here are not bad at all. I am going to go over to AA today to see what they think and hopefully this will all go away. Any other suggestions?
I got the same problem and the way to fix it is change the bulbs and MAKE sure you push in the bulb as hard as you can.... I did it the normal way the first time and for some reason it didn't light up.....my .02
it has to CLICK in place in the socket.
Rear Brake lights
I had this problem and found the answer thru these boards. The bulb i bought had a small nipple on the bottom from manufacturing, this nipple stops the bulb from inserting all the way into the harness. When i installed the new bulb - At first I had running lights but no brake light.
Well, i sanded down the nipple on the bottom of the bulb and bingo the bulb popped in and the brake lights work!!
I am under the impression that a bulb from nissan doesnt have the nipple, but i would have to pay for the bulb and pick it up when it comes in at the dealer i go to.
fixed... and the answer is... the dumbass who replaced them for inspection did not push them in the whole way. I pushed harder on the bulb and herd the second click you guys were talking about... problem fixed so thanks again!
I have a problem that hopefully can be solved easily. I made the mistake of replacing a tail light without pushing the bulb in all the way. It lit up, but it did not click all the way when I pushed it in. Anyway, today I saw that the bulb had actually fallen into the tail light cover, whatever it is called. I can not reach it through the hood, as the bulb has rolled to the side. Is it possible/difficult to take off the passenger side tail light cover? Any suggestions? Thanks In advance.
Originally Posted by Zero Deuce SE
Did he check them after he replaced them? If it was for an inspection I would think he checked after he replaced them.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
