Transmission whine. Help.
Old Mar 7, 2005 | 09:35 AM
hokiemax's Avatar
Car: 2000 GXE 5pd
Symptom 1: The tranny whines when the car is parked and the gear in neutral. The whining stops when I press in the clutch.
Symptom 2: It whines in 1st gear.
What could be the cause of this? I don't remember when it started doing this.. I did change the tranny fluid with synthetic couple years ago. Can low/too much tranny fluid be the cause of this? I'm pretty sure I put in the proper amount.. If the tranny oil leaks, where do I need to look?
HELP!
Old Mar 7, 2005 | 10:57 AM
kcowden's Avatar
Possibly the clutch throw-out bearing is bad. Do you spend a lot of time on the clutch... living in NOVA I know you spend a lot of time in traffic. Stop & go traffic is hard on a clutch. Take it to the dealer for a confirm.
Old Mar 7, 2005 | 11:31 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I hear this is pretty common, DAVEB just replaced his trans due to this problem.
You should PM him and see what he says.
Old Mar 7, 2005 | 11:56 AM
NiZMo1o1's Avatar
Throw out bearing needs to be replaced, Better ge that fixed before the Throw out bearing cuase more wear and tear in on the clutch and peice might scratch up the flywheel.
Old Mar 7, 2005 | 08:16 PM
hokiemax's Avatar
geeeez....
so how much is it to replace the throwout bearing? Anything that I should watch out for while getting this performed ?
Old Mar 8, 2005 | 08:35 AM
kcowden's Avatar
Originally Posted by hokiemax
geeeez....
May want to get ready to replace the clutch itself while there in there. More than likley your clutch plate is close to minimum thickness already, so may as well replace it for good measure. Take it to Brown Nissan in Fairfax and ask for "Buzz" and tell him your and tell him that a friend of "Rob" told you to look him up for service. Good luck.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
