WIERD LOW-END power loss 2002 3.5L
Old Mar 9, 2005 | 02:54 PM
Anzioblack44's Avatar
Today i took an extended drive. As i pulled onto a highway i had very very little get up... felt like 5 people in the car. at the next stop i gave it some gas with traction control off.... no wheelspin... ??? about 15 min later when stuck at a RR crossing, i shut the car off, waited a few min.
Fired her back up and Wiola all my torque was back...?? Is this a Vias problem? I had no check engine lights illuminated, i checked the intake tract to make sure i hadnt sucked up a small animal. Power loss was idle to redline, but obvious at speeds like 2000-4000rpm. Car runs smoothly and fine now...
When i pick up my Bose stereo , im gonna ask about it
Old Mar 9, 2005 | 03:00 PM
NmexMAX's Avatar
dot dot dot ...
Can't be VIAS because that's would be most noticeable only in the high end. There's a TSB on it. MAF.
Old Mar 9, 2005 | 04:19 PM
NYPD-Arnold's Avatar
Z
Your MAF is going slowly. Or maybe a bad throttle body. Have both inspected.
Old Mar 9, 2005 | 05:01 PM
Kevin's Avatar
hmmm. ive noticed some intermittent low end power loss, but nothing too drastic. i wonder if my MAF has a terminal disease ?
Old Mar 9, 2005 | 05:25 PM
chigga's Avatar
yeah i have this problem ONCE in a while and its madd annoying. it just feels gutless when u punch it. im gonna get it done in the spring as well as the wind noise tsb.
Old Mar 9, 2005 | 06:04 PM
F23A4's Avatar
I had that happen to me once. But I'd suspected that it was bad gas (from a local no-frills station) and changed to Sunoco Ultra. I havent had that problem since.
Old Mar 10, 2005 | 01:46 PM
im thinkin coulda been bad gas, fuel filter, etc... filled up with BP/Amoco ult. no issues yet
Old Mar 10, 2005 | 02:59 PM
paralyse's Avatar
I Miss My Maxima
Your transmission control module went into limp mode. This happens on mine sometimes after periods of excessive wheelspin. Restarting the engine should reset it.
Old Mar 10, 2005 | 03:56 PM
MiniRX7's Avatar
This happened to me last summer.. Mind you my car is a 6 speed.
I could not drive with the A/C on. Car would not accelerate unless i was past 3500rpms. No pull, i would have to bury to throttle. No engine lights.
Took the car in for a throttle body cleaning, Fuel injector cleaning, oil change, etc... and all of a sudden all the power is back.. and back since last summer.
Old Mar 10, 2005 | 05:46 PM
F23A4's Avatar
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Bluenissan
Sep 20, 2015 08:54 PM
Mahmuth
Sep 17, 2015 11:45 AM
