Illumina settings?
Old Mar 10, 2005 | 11:42 AM
Kabdog2K3_Max's Avatar
Illumina settings?
Getting ready to install my Illuminas and H-Techs. What settings are you guys running with the Illuminas? Also, is 5 the hardest or softest setting? Thanks.
Old Mar 10, 2005 | 12:00 PM
Deckdout2's Avatar
Play with my balls
5 is the hardest. I have mine at 3F/4R. I like it fine, handles great and ride is not that bad. It's at 3F/3R from factory, and the back end for me just wasn't tight enough. Hope that helps.
p
Old Mar 10, 2005 | 06:10 PM
Bensmax00's Avatar
i have mine set at 4f/5r and i love it--corners very nicely--but does ride a lil bumpy on those not so new roads--but its still fun
Old Mar 10, 2005 | 06:24 PM
Omegasrk's Avatar
I have my Illuminas set at 5F/5R running with Eibach Progressive springs. The ride is bumpy, but handles great.
Old Mar 10, 2005 | 06:27 PM
irish44j's Avatar
retired moderator
it all depends on the suspension setup you are running, including RSB, etc...
With the LTB and RSB on my car, I have the illuminas at 3F/3R or 4F/3R if I'm doing some spirited driving. The higher you crank up the back relative to the front (i.e 3F/5R) the more oversteer you will have. conversely a 5F/3R setting will give you alot of understeer.
You should really go out to a big lot when you get the car and test out various settings for the best setup with your other suspension monds. generally, it's agreed upon that just a slight amount of understeer is the safest and most stable setup (so you don't lose the tail).
I see from your site you have no other suspension mods, so you should probably go with a firmer rear setting (would be softer if you had a RSB)....
If you're running 19's, I would suggest a 3F/4R set, for the best ride quality and handling....
Old Mar 10, 2005 | 06:33 PM
JClaw's Avatar
I have RSB and FTSB and I'm interested in Tokico Illuminas as well as their springs since Custommaxima has a group deal going on right now (149$ for all 4 springs).
Problem is, I am still riding on the stock 15" Sawblades. What kind of effect will this have?
Old Mar 10, 2005 | 10:44 PM
JClaw's Avatar
bump..........
Old Mar 10, 2005 | 11:27 PM
crispykid717's Avatar
Bigger than Jesus
Mine are set at 3f/2r. Ride is awesome. On Eibach springs until Thursday then I'll be on H-techs.
Old Mar 11, 2005 | 06:36 AM
maximillus's Avatar
what about for progress springs?
Old Mar 11, 2005 | 07:38 AM
maxima0002's Avatar
achieve a "Boat-like" feel with settings set to: 1F/2R (with H&R springs)
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
