Pics of Lower Control Arm ES bushing install
Old Mar 12, 2005 | 12:39 AM
HNDA ETR's Avatar
Still Here... IM me for more..
Pics of Lower Control Arm ES bushing install (and motor mounts)
What a pain in the **** to do!
Here's some pics:
Old Mar 12, 2005 | 12:41 AM
HNDA ETR's Avatar
Even though the bushing supposedly isn't pressed on, mine seemed frozen on... This is the hardest part of the whole install, getting this off:
This bushing easily presses out:
Old Mar 12, 2005 | 12:44 AM
HNDA ETR's Avatar
Here's the replacements:
We just lubed this one up good, and stepped/jumped on it until it slid on:
Slides right in:
Old Mar 12, 2005 | 12:46 AM
HNDA ETR's Avatar
Finished product:
Old Mar 12, 2005 | 01:00 AM
HNDA ETR's Avatar
Here's a before and after of the ES Motor Mounts:
FYI - Tony did these in 22 minutes with NO PRESS!
Old Mar 12, 2005 | 01:05 AM
HNDA ETR's Avatar
Installed:
Old Mar 12, 2005 | 01:17 AM
Omegasrk's Avatar
How was Tony able to remove and press in the motor mounts without a press?
Thanks.
steve...
Old Mar 12, 2005 | 01:28 AM
HNDA ETR's Avatar
Thanks.
steve...
Here's his exact quote:
A drift, a vice, and a hammer. Oh, and of course, some good old fashioned elbow grease!
T.
---- Roy <Roy.xxx@xxxxxx> wrote:
> Sweet! How'd you get the old ones out and the new ones in?
Old Mar 12, 2005 | 01:30 AM
HNDA ETR's Avatar
Basically, I believe he took a BFH (big freakin' hammer) and pounded the old ones out... He said the new ones went in pretty easily...
Old Mar 21, 2005 | 08:20 PM
Menasor's Avatar
When you were removing the lower control arm ball joint from the spindle, what did you use to get it off?
Old Mar 21, 2005 | 09:17 PM
HNDA ETR's Avatar
We didn't remove the ball joint from the spindle...
We removed the nut from the top of it and removed it all as one unit...
Old Mar 21, 2005 | 09:26 PM
roll4life's Avatar
sorry if this seems dumb..but what exactly does the control arm do?
Old Mar 22, 2005 | 07:19 PM
Menasor's Avatar
Sorry, I should have worded things diffrently, but I assume you are saying that you took off the 19mm off the lower ball joint and seperated the lower ball joint from the spindle. I think you thought I was asking how you seperated the lower ball joint from the lower control arm. Is that what you thought I meant or are you saying you took the spindle and lower control arm all off as one unit? From your pics it doesn't look like you did that. When I was replacing the wheel bearings I used a pickle fork to detache the lower ball joint from the spindle but almost ripped the ball joint boot. Had I done so I wouldn't be able to buy just the lower ball joint because Nissan sells the lower control arm and lower ball joint as a unit. That is why I ask what kind of tool you used to seperate the lower ball joint from the spindle without tearing the boot.
Old Mar 24, 2005 | 11:27 AM
HNDA ETR's Avatar
I think we're on the same page now... if you look in the pics, you can see that the ball joint is still attached to the control arm...
Here's what Tony said about removing it:
"... hit the knuckle (part that holds the bearing, caliper,etc.) with a hammer to shock it free. Not the ball joint itself... One good whack (with a brass hammer). A ball joint seperator should not be used because it could possibly damage the grease boot."
Old Mar 24, 2005 | 01:02 PM
SPiG's Avatar
SomePsychoGuy
Yeah I just got my car back from a shop that changed my LCA bushings like 2 hours ago. I am really glad I let someone else do it. I was just too lazy to have to deal with changing them and the problems that were going to pop up.
I didn't know the 5th gen LCA bushings had become available.
I already feel that my steering response is a little better. Although I was just trying to rush back to work and really couldn't test them out too much. I hope you like yours.
Old Jul 5, 2006 | 11:35 PM
dko's Avatar
dko
duck and cover
is there a step-by-step anywhere? i want to get comfortable with it before i do it on sunday. i've done spring/strut installs twice now and am fairly mechanically inclined. i'll also have help, but it's always nice to know exactly what you're doing.
Old Jul 6, 2006 | 05:15 AM
Puppetmaster's Avatar
AFAIK, Roy's pics are as step-by-step as there is out there. Did you check the Motorvate site or VQPower (pretty sure they don't have it either though)?
Old Jul 6, 2006 | 06:19 AM
Deckdout2's Avatar
Play with my balls
I need to get this done as well. I'm glad I saw this, I don't feel like paying someone else to do this job. This past weekend I finally did the shifter bushings and front sway bar bushings, and what a difference. I wonder how she will handle after this mod.
This thread should be in the stickies of the Advanced Suspension Thread as well, Joel. Maybe you can hook that up with one of your post already in that section.
Old Jul 6, 2006 | 06:37 AM
You = pwn3d by teh Stickies
2nd How To link...
http://forums.maxima.org/showpost.ph...14&postcount=2
Old Jul 6, 2006 | 07:24 AM
Deckdout2's Avatar
Play with my balls
2nd How To link...
If you check out Kimberly's thread in the regionals section, i posted that i don't read stickies, they're overrated.....
Old Jul 6, 2006 | 07:31 AM
SoonerFan's Avatar
Cletus
all newbies have to read the stickies...us veterans already know everything
Old Jul 6, 2006 | 08:04 AM
Deckdout2's Avatar
Play with my balls
that or we make up the rules as we go....
Old Jul 6, 2006 | 09:37 AM
dko's Avatar
dko
duck and cover
neither has it. i think both sites were last updated before ES got these back in stock. although vqpower has a supplemental writeup on the LTB install that i actually found easier to follow than matt's http://www.vqpower.com/v2/modules.ph...howpage&pid=72
Old Jul 6, 2006 | 10:03 AM
MaxBoost925's Avatar
Drug Money
am i a veteran yet?
Old Jul 6, 2006 | 01:50 PM
Deckdout2's Avatar
Play with my balls
Originally Posted by MaxBoost925
am i a veteran yet?
You have to be 18 or older.
Old Jul 6, 2006 | 02:26 PM
dko's Avatar
dko
duck and cover
am i a veteran yet?
registered Aug 2005? nah, not a veteran
Old Jul 6, 2006 | 02:35 PM
SoonerFan's Avatar
Cletus
961 posts?? nah, not a veteran
Old Jul 6, 2006 | 03:36 PM
AllGo's Avatar
I would have to disagree with you on that statement.
High post count = a bunch of useless typing
However, I just made myself a hypocrite with this post.
Old Jul 6, 2006 | 05:56 PM
The Law's Avatar
I R The Law
am i a veteran yet?
PWNED!!
Old Jul 7, 2006 | 01:13 AM
dko's Avatar
dko
duck and cover
more OG than you
oh yeah, FYI, the energy suspension products come with instructions and pictures. These help ALOT. i'll check with the ES people to see if they're cool with me posting them here.
maxocar
Aug 21, 2015 12:57 AM
AT978
Aug 15, 2015 06:39 PM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
00 Max
Aug 4, 2015 07:09 PM
