View Poll Results: what would you replace first or suggest as a fix
MAF
59.09%
Spark Plugs
0%
Clean Throttle Body
13.64%
Clean/Replace Air Filter
4.55%
Replace Fuel Filter
4.55%
Might be transmission related
9.09%
Reset ECU
0%
Go Back to Stock Air Box
0%
Other (please specify in a post)
9.09%
Voters: 22. You may not vote on this poll
not another HESITATION thread!!!
Old Mar 15, 2005 | 07:29 PM
fishhouse's Avatar
ok...i think i know the answer already, but just wanted a second opinion.
the problems:
1.) doesn't accelerate when first pulling away: just after starting car, when accelerating onto the highway, pressing the gas doesn't have an effect. like not getting fuel. almost feels like getting ready to stall out. i have to let of the gas and coast for a few seconds and then reapply gas. or you can stomp the gas to the floor and it will jerk the heck out of you when it finally kicks in.
2.) hesitation: when accelerating 1/2 - 3/4 throttle (not quite WOT, but not granny driving) and always around 3000 - 3500 RPM and sometimes at other RPMs, the car is sluggish. hesitates for a second and then kicks back in. like a couple of shudders while accelerating - classic "hesitation" as i've heard it described.
3.) loss of low-end power/torque: pulls like a stock civic. used to have way more off the line grunt. some if not all of this could be due to my intake. just seems worse lately.
3.) low gas mileage: i used to get 300-330 miles per gallon (premium fuel). my last tank was 250 miles per gallon.
Old Mar 15, 2005 | 07:35 PM
fishhouse's Avatar
idling doesn't seem all that bad - nothing noticeably unusual.
starts have been somewhat harder lately - although that could be due to cold weather.
i've tried carb/injector cleaners in the last several fuel fills - didn't help.
the specs on my ride:
2k, 55k miles, injen intake with generic cone filter, original plugs, original fuel filter, hyper grounding kit, syn-blend oil, recent tranny drain/fill and oil change, original MAF, no codes being thrown.
i'm thinking of trying MAF change with an throttle body clean, seaform, reset ecu and air filter clean first. then i'll move onto plugs if that doesn't have an effect.
don't really care to do fuel filter change - sounds like a pain to do.
suggestions, comments, personal experiences?
vote for what you would do first - taking into consideration cost and install difficulty.
Old Mar 15, 2005 | 07:56 PM
okay's Avatar
I say MAF because hesitation at 3000 rpm seems to be what everyone has been experiencing, i have yet to change mine though and i'm at 78k miles.
Old Mar 16, 2005 | 03:02 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Maf //123456789
Old Mar 16, 2005 | 04:16 AM
fishhouse's Avatar
i forgot to add COILS to the poll. post or select OTHER if you like that one.
Old Mar 16, 2005 | 04:19 AM
Lontar1's Avatar
If they were Coils you should have misfire and SES on.....
Old Mar 16, 2005 | 09:40 AM
Drewhos's Avatar
I would try the VAIS also.
http://www.cardomain.com/memberpage/763858/5
Old Mar 16, 2005 | 09:46 AM
Drewhos's Avatar
Sorry, I meant VIAS.
Old Mar 16, 2005 | 01:32 PM
Airgar's Avatar
try putting the stock air box in first and doing a throttle body cleaning. I had the same problem and now remove the cone filter in the winter as it allows too much cold air and confuses the sensors. If your filter is a K & N type, the spray eventually coats the MAF coil and again effects the readings and causes you nothing but grief
Old Mar 16, 2005 | 01:51 PM
adithius's Avatar
You wont necessarily get a code at first if it is your coils. It can be related to your coils. Test them with a multi-meter and check for infinite ohms.
Old Mar 17, 2005 | 02:40 PM
fishhouse's Avatar
Originally Posted by Drewhos
sounds interesting. what is that JB Weld stuff mentioned in the link and where do you get it?
anyone else done this?
Old Mar 18, 2005 | 05:36 PM
fishhouse's Avatar
well, only 15 votes on the poll...but as i suspected, most think that the MAF seems the likely problem.
going to head to the stealership this weekend and pick one up...who needed that $100 anyways?!
i'll let you guys know how the replacement goes.
Old Mar 19, 2005 | 11:34 AM
fishhouse's Avatar
just ordered a MAF from Dave Burnette for $90.11 shipped UPS.
he's at 1888-254-6060 for anyone interested. super nice and hassle free.
can't wait to get it installed!
Old Mar 25, 2005 | 09:13 PM
illmattic979's Avatar
There isn't anyway to test the sensor before replacing it?
Old Mar 25, 2005 | 09:24 PM
fishhouse's Avatar
no...don't think so. you could unplug it completly...but that would surely throw a SES code and mess with you.
Old Mar 25, 2005 | 09:27 PM
fishhouse's Avatar
by the way, actually got the new MAF today and installed it.
after a brief spin after install, the butt dyno says:
hesitation gone
pulls harder
seems to be smoother overall
seems like i have back some of the low-end grunt my intake killed
overall...i think it was well worth the $90 and has seemed to resolve my issues. i'm know for sure this week when i get a chance to drive it more.
Old Mar 26, 2005 | 05:33 AM
ZIPPIN's Avatar
Mauja He Mauja
every 5th generation owner should have an extra maf, like irish does
Old Mar 26, 2005 | 11:53 AM
cptn_zippy's Avatar
What's the current part number?
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
jchronis2552
Sep 21, 2015 05:52 AM
