pictures behind the gauge cluster?
Hi, I tried searching but it's down. I am currently a g35 owner and recently i messed up my gauge cluster because i was redoing my blue lights and was wondering if anybody have any pictures or description of behind the gauge cluster? If it's the same I can buy a maxima one used and swap out my broke rpm gauge since the g35 clusters are extremely hard to come by.
What i'm looking for is if the RPM unit is soldered in to the electronic board with 4 connections. There is also a hole in the middle of the 4 soldered points and is screwed on with two screws. detailed pictures would be great. thanks!
I have pics on my computer at home because i am working on the same thing you are attempting. BUT, I am at work right now.
if no one else provides pics for you by the time i get home i will post some up for you.
BTW, Nice a$$ car!
if no one else provides pics for you by the time i get home i will post some up for you. BTW, Nice a$$ car!
BTW, Nice a$$ car!
if you could get the pics, that would be GREAT. I'm thinking maybe the connections will be the same that I could solder on the points that are screwed on as dr roy stated.
Originally Posted by accordfreak
thanks
Yes, the tach on the cluster has 4 connections going to it. Actually, these 4 connections are held on with 4 screws which gives power to the circuit board. I have a older GXE guage cluster just lying around, so I'll try to post pics later.
bigfrank
Oct 1, 2015 12:51 PM
