car would not start
Old Mar 22, 2005 | 05:57 PM
zamac_man's Avatar
car would not start
I just tried starting my car but it would not even try to start. It was like I was not even turning the key to the starting position. All of the lights came on when I tured the key. Headlights, battery light, seatbelt and all those other lights. THe car was not making any starting noise at all. I started to push it out of the way but when I moved it by pushing it it started.
Could this be the altinator(sp)?
I got no ses light
Old Mar 22, 2005 | 06:00 PM
LA02MAX's Avatar
are you battery terminals connected properly? mine did the same thing and the negative terminal was just a bit loose..problem fixed
Old Mar 22, 2005 | 06:05 PM
zamac_man's Avatar
I will check that, it just came from the dealership and they had the battery disconnected.
Old Mar 22, 2005 | 06:12 PM
lalaMAX's Avatar
maybe your starter.... my old car did exacly da same thing when her starter is gone...
Old Mar 22, 2005 | 07:31 PM
sascuderi's Avatar
Make sure the tranny is in park.
Old Mar 22, 2005 | 09:00 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
U can't push start a automatic, he was saying its a auto. I would look at the obvious things like battery wires connected 1st. Then I like to give the starter a test. I get someone to try to start it, while I beat on the starter with the tire wrench from the trunk. This almost always works on the Max to get the engine started. Its a common problem for cars with over 100K miles - alternator or starters go out.
Old Mar 22, 2005 | 10:07 PM
Stardust's Avatar
F---ing Kangaroos
Like yours? Are you ever going to fix that?
Old Mar 23, 2005 | 01:42 AM
ChiGuy_82's Avatar
Mine too, not my Max but i my '99 trooper. The dome lights, and headlights were fine but it didnt do anything when i turned the key. The shop said that it was the starter.
Old Mar 23, 2005 | 02:12 AM
2k3blk6spd's Avatar
I had this problem with my car two weeks ago.It was the alternator and the battery was bad also.Kinda surprised me because I would never expect the alternator to go out at only 41k.
Old Mar 23, 2005 | 03:49 AM
ChiGuy_82's Avatar
Your lights would turn on with a bad batter and alternator?
Old Mar 23, 2005 | 08:58 AM
zamac_man's Avatar
I took it the dealer a couple months ago because the alternator was making a nosie. THey said it was going to mess up but they can't do anything till it does. But how come after I pushed it, then put it back in park it starts? Drove it today with no problems also.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
