Right blinkers dim and flasher flashes too fast!
Old Mar 24, 2005 | 06:47 PM
maximillien's Avatar
anyone had this problem, I dunno what happened, everything still works, but yet my right blinkers be blinkin too fast and it's real dim....even on the inside i see the right signal flash fast too whats goin on....is it cuza my system? im MECP certified and im still stumped....
Old Mar 24, 2005 | 06:57 PM
Trance Artur's Avatar
Probably have a bulb out.
Old Mar 24, 2005 | 07:22 PM
ZeRo MaX's Avatar
yeah check your signals and all your lights... one of them is out.. if the one is dim... maybe change that...
Old Mar 28, 2005 | 06:49 PM
both front n rear tho? but it still shines not like its not on!
Old Mar 28, 2005 | 08:51 PM
Max20SE00's Avatar
when they blink fast that usually means a bulb is out somewhere or one is bad, just check them all.
Old Mar 29, 2005 | 01:12 AM
FanaticMadMax's Avatar
the bulb is out, depending on which side, right or left blinker is blinking too fast, if the left one is blinking fast, then it's your left side either front or rear bulb is out, that's how you know. One of the nice thing to know when your bulb is out.
Old Mar 29, 2005 | 05:17 AM
Y2KSilvahSE's Avatar
If it's not the bulb (prolly is) then I have seen a loose ground do this also...
Old Mar 29, 2005 | 01:36 PM
thanks i will check this weekend!
gavin68
Sep 18, 2021 12:36 PM
dshinn
Sep 26, 2015 08:07 PM
BrandonCause
Sep 14, 2015 10:41 PM
