WHooo sound coming from wheel area, Help!
Originally Posted by Epacy
Mine was my bearing too. I got it replaced last week. A good way to tell is if you jack the wheel off the ground and then push in on the wheel from the bottom of the wheel and see if there is any play in the wheel. You shouldn't be able to push it in or out. If so, that means your bearing is worn.
I just swapped my winters for my summers. The woo-woo noise has gone. I guess it was either the tire or rim. Or maybe it was because the idiots at my dealership put my uni-directional snow tires on the wrong side of the car!
Originally Posted by UsedNeedle
Wonder if anyone has just changed the bearing and not the hub assembly ?
Apparently the bearing my local garage can get , but the hub is dealer only part....per garage
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
