Sway bar for an SE?
Old Mar 31, 2005 | 10:02 PM
Anarchist's Avatar
Sway bar for an SE?
I know that the SE has stiffer suspension than the GLE and GXE models, so I'm guessing a sway bar would have less of an effect on it. I wouldn't be using the car for anything other than normal driving (although I do drive pretty fast a lot) so my question is: would a sway bar still give a pretty noticible difference for an SE?
Old Mar 31, 2005 | 10:07 PM
Kruppa's Avatar
I have a SE and it made a huge difference in my handling (Progress...but they're all pretty much the same)
Old Apr 1, 2005 | 02:36 AM
panda_1's Avatar
definately, i too have the progress and love it.
Old Apr 1, 2005 | 03:18 AM
808MAX-SPEC's Avatar
You will notice the difference while taking the turns. Flat or less roll almost like a sports car. Although you could get an even stiffer suspension.
I switched to Stillen because the Progress was making this annoying klunk whenever i went over a speed bump, driveways and dips in the freeway. Because the bar is mounted to the axel, the control arm snaps it back into place causing the klunk. There are steps to prevent this but it will loose the effectiveness of the sway bar. Since the Stillen does not mount to the axel, there is no klunk at all.
Both sway bars will perform the same. Progress is cheaper. But i like the Stillen since it doesn't make noise.
Old Apr 1, 2005 | 03:29 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have the Stillen knockoff and it makes a big difference.....
Old Apr 1, 2005 | 05:05 AM
kcowden's Avatar
Yes it will... a noticeable difference. I got the progress and am very satisfied with it.
Old Apr 1, 2005 | 06:56 AM
edgenuts's Avatar
I don't have a heavily modded car but I put on the progress RSB and holy crap what a difference. I got it on a GD on this board for 109 (128 shipped i think).
Old Apr 1, 2005 | 07:03 AM
Puppetmaster's Avatar
Man... I shoulda gotten it then...
Anyways... if ya don't have a suspension upgrade... this is definitely a must-do.... and even if ya are dropped, it makes a difference... its highly recommended... I just haven't gotten one cuz I'm broke...
Old Apr 1, 2005 | 07:09 AM
Deckdout2's Avatar
Play with my balls
I believe in them. Especially, lane changes on the highway are more definitive. Reduces roll a little, but the fstb along with the sway reduced my body roll significantly. To completed the box, lowering would be the next step. But, definately invest in the sway bar, and if you don't like it then sell it to Puppetmaster for half the price.
Old Apr 1, 2005 | 07:31 AM
Anarchist's Avatar
Thanks for all the input. I shall be ordering one as soon as I have the money.
-Mark
Old Apr 1, 2005 | 11:19 AM
Dayam right...
:attention
Hope ya enjoy the new email account, Mark....
Old Apr 1, 2005 | 02:47 PM
Talyan03's Avatar
i have 03 se and i love my stillen sway bar. if i knew that the car would feel this way with it , i would of purchase the bar long time ago
Old Apr 1, 2005 | 06:14 PM
cwc412's Avatar
Forgive my ignorance, but is a sway bar and a front shock tower brace the same thing? If so, will it reduce understeer in my Max? I would like the Max to oversteer rather than understeer. Any suggestions? My car is bone stock and I would like to maintain the ride quality. Thanks in advance for your help.
Old Apr 1, 2005 | 09:58 PM
They are not the same thing... see here for some short descriptions:
https://maxima.org/faq-5-Suspension.html
If you'd like more oversteer, then get a rear sway bar (RSB). An RSB will lead to a more sensitive tail end, so it may seem slightly more lively and bumpy since the rear suspension is tightened up.
Also, do a search for more threads that discuss this in greater detail, there are many out there. Details on how to search using Google or Yahoo (since you're not a donating member, the site's built in search function will not work for you) are in the Stickies, as is a lot more useful info in the FAQs, How-Tos, etc...
Old Apr 2, 2005 | 10:24 AM
Myfirstnissan's Avatar
Well for my 2cents i put the stillen FSTB and the rear sway bar and the just got sweeter in the handling.
Old Apr 2, 2005 | 10:47 AM
And before anyone asks... the Stillen knockoffs on eBay do the exact same thing for less than half the price... .. and yes, that it is a fact...
Old Apr 2, 2005 | 12:42 PM
maseo77's Avatar
Been lookin on ebay but cant seem to find any knock off's??
Old Apr 2, 2005 | 05:19 PM
Anarchist's Avatar
Well .. my genuine Stillen Rear Sway Bar is on the way.
-nuff said.
Old Apr 2, 2005 | 06:38 PM
Maximax2's Avatar
Not correct - the Panhard bar makes the noise by hitting the RSB clamp, and this can be avoided by placing the multi-beam clamps close together. This has very little impact in the effectivess of the sway bar, it's the placement of the trailing arm clamps that makes a difference. I have the Cattmann bar, works great, zero clunk.
Old Apr 2, 2005 | 08:32 PM
NisMo-Max's Avatar
I got the stillen Rear Sway Bar, and i thought that was the best handling mod, I suggest getting it. i Felt it as soon as i installed it and put it in drive.. I once took a turn and i was flooring it, i put it to the max and almost lost it, but i didnt because the rear sway bar caught on and kept me on the road.. But Dont try what i did until you get used to it and feel what your max can handle...
Old Apr 3, 2005 | 11:45 AM
RSBs or FSTBs? RSBs can be hard to find.... the OTTO FSTB is the same as Stillen's but it just says OTTO... as far I can tell...
vs
Old Apr 3, 2005 | 11:48 AM
Here's one:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
vs
I think ya need to look harder, Maseo77....
Old Apr 3, 2005 | 11:50 AM
-nuff said.
Um... congrats... ?
Old Apr 3, 2005 | 12:20 PM
maseo77's Avatar
Here's one:
vs
Well I went here and found one.
http://www.customenterprise.com/view.../vts/design004
Old Apr 3, 2005 | 12:27 PM
That should work out well for ya....
Old Apr 3, 2005 | 01:06 PM
Maxima-Ness's Avatar
theyre all pretty much the same, but the difference with vs without is very noticable.
Old Apr 3, 2005 | 01:15 PM
GBAUER's Avatar
Got the same problem... but this summer, on the other hand! Lowering springs, RSB, and a whole lotta other goodies to come! The FSTB did, however, make a HUGE difference on it's own.
Old Apr 3, 2005 | 07:16 PM
Anarchist's Avatar
Um... congrats... ?
why thank you
gman214
Sep 25, 2015 03:03 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
