00-03 max/00-04 I35 Wheel Alignment Spec Sheet?
Old Apr 1, 2005 | 08:38 AM
leeI35's Avatar
G37S > I35 > UR Max
Hey guys, I am in the DC area (land of potholes) and I am trying to get my alignment done. I have about 4k miles on my car and the alignment is already off. Instead of going to the dealer which is really far from me, I went to firestone (got a really good mechanic that does my modding) and they did my alignment before however, the steering wheel was still off-center but the car still drives straight. Their alignment specs for infiniti/nissan are not the same as the dealer specs, so everytime they try it's either off to the left or off to the right.
I am looking for either the infiniti or nissan wheel alignment spec sheet since i have a lifetime wheel alignment hook up with firestone. Anyone have any info or atleast can point me to the right direction?
Old Apr 1, 2005 | 10:42 AM
HenryNYC1's Avatar
Service Data and Specifications (SDS)
GENERAL SPECIFICATIONS (FRONT)
=NFSU0020
Suspension type Independent MacPherson strut
Shock absorber type Double-acting hydraulic
Stabilizer bar Standard equipment
FRONT WHEEL ALIGNMENT (UNLADEN*1)
NFSU0021
Tire size 17-inch tire 16-inch tire
Camber
Degree minute (Decimal degree)
Minimum −1°00¢ (−1.00°)
Nominal −0°15¢ (−0.25°)
Maximum 0°30¢ (0.50°)
Left and right difference 45¢ (0.75°) or less
Caster
Minimum 2°00¢ (2.00°)
Nominal 2°45¢ (2.75°)
Maximum 3°30¢ (3.50°)
Kingpin inclination
Minimum 13°30¢ (13.50°)
Nominal 14°15¢ (14.25°)
Maximum 15°00¢ (15.00°)
Total toe-in
Distance (A − B)
mm (in)
Minimum 0 (0)
Nominal 1 (0.04)
Maximum 2 (0.08)
Angle (left plus right)
Minimum 18¢ (0.30°)
Nominal 24¢ (0.40°)
Maximum 30¢ (0.50°)
Wheel turning angle
Full turn*2 Inside
Minimum 29°30¢ (29.50°) 36°00¢ (36.0°)
Nominal 33°00¢ (33.0°) 39°30¢ (39.50°)
Maximum 34°00¢ (34.0°) 40°30¢ (40.50°)
Outside
Nominal 28°30¢ (28.50°) 32°00¢ (32.00°)
*1: Fuel, radiator coolant and engine oil full. Spare tire, jack, hand tools and mats in designated positions.
*2: On power steering models, wheel turning force (at circumference of steering wheel) of 98 to 147 N (10 to 15 kg, 22 to 33 lb) with
engine idle.
LOWER BALL JOINT
NFSU0022
Swinging force “A”
(Measuring point: cotter pin hole of ball stud) N (kg, lb)
8.0 - 54.4 (0.82 - 5.55, 1.80 - 12.23)
Turning torque “B” N·m (kg-cm, in-lb) 0.50 - 3.40 (5 - 35, 4.3 - 30.4)
Vertical end play “C” mm (in) 0 (0)
FRONT SUSPENSION
SU-14
This is taken from my factory service manuel for a 5th Gen. hope this helps.
Old Apr 1, 2005 | 01:38 PM
leeI35's Avatar
G37S > I35 > UR Max
=NFSU0020
NFSU0021
Camber
Caster
Kingpin inclination
Total toe-in
Distance (A − B)
mm (in)
Minimum 0 (0)
Nominal 1 (0.04)
Maximum 2 (0.08)
Minimum 18¢ (0.30°)
Nominal 24¢ (0.40°)
Maximum 30¢ (0.50°)
Wheel turning angle
Full turn*2 Inside
Outside
engine idle.
LOWER BALL JOINT
NFSU0022
Swinging force “A”
FRONT SUSPENSION
SU-14
My GOD you are the man, thanks a billion. I am going to them first thing in the morning.
Old Apr 3, 2005 | 08:40 PM
HenryNYC1's Avatar
hehhe, anytime. I have the CD version of the manuals
Old Sep 28, 2007 | 10:50 AM
chandmx's Avatar
Do you have one for 18-inch tires?
Does the width matter at all?
Old Sep 28, 2007 | 12:52 PM
NmexMAX's Avatar
dot dot dot ...
Thanks for bringing back an ancient thread .
It doesn't matter the wheel size so follow the above specs.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
Hdnseek
Sep 9, 2015 05:55 AM
dcam0326
Sep 8, 2015 11:02 PM
