ECM diagram
Old Apr 1, 2005 | 02:40 PM
chris'smax's Avatar
ECM diagram
Can someone post or email me the ecm diagram for a 2000 fed spec.
Chris
Old Apr 1, 2005 | 03:27 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
...what part/pin/input/output are you looking for specifically?
Old Apr 1, 2005 | 04:12 PM
chris'smax's Avatar
for hooking up injector harness. I hooked it up yesterday and couldn't get a duty cycle reading. I then looked at my FSM and realized it is for the european maxima and i don't know if their ECU is different
Old Apr 1, 2005 | 06:06 PM
IceY2K1's Avatar
Injector #1:Red/Black to ECU pin#101
Injector #2:Red/White to ECU pin#103
Injector #3:Red/Yellow to ECU pin#105
Injector #4:Red/Light Blue to ECU pin#107
Injector #5:Light Blue/White to ECU pin#102
Injector #6:Purple/Red to ECU pin#104
Old Apr 1, 2005 | 06:14 PM
IceY2K1's Avatar
BTW, ignore the tach/knock/MAF/ground/TPS/Power/etc. pins in that diagram, since they're for a 2K2.
Old Apr 1, 2005 | 06:33 PM
IceY2K1's Avatar
Tach - Pin #25 White/Green.
MAF - Pin #61 White.
TPS - Pin #91 Light Blue/White.<~~~DOUBLE CHECK!!!!!
Power - Pin #110, #112 Red/Green.
Ground - Pin #48, 57 Black.
Old Apr 1, 2005 | 06:40 PM
chris'smax's Avatar
well $hit. I have the harness hooked up correctly. The support tool isn't showing me the injector duty cycle. Do you have to activate it after installing the harness?
Old Apr 1, 2005 | 08:10 PM
IceY2K1's Avatar
Once you're "Online"...just follow the manual page 35, ie click "Input Data Setup" and check box the injector options.
I can't access that, I only have the Support Tool and you must be communicating to use the Real Time/Graph/Record modes.
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MaxDD
Sep 24, 2015 06:40 AM
kjlouis
Sep 14, 2015 11:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
